1 members (2-Ton), 133 guests, and 1 robot.
Topics128,114
Posts1,056,287
Members48,439
#1360734 05/17/2020 6:20 PM
Hi I installed a 338 gear set in the original rear. The truck is a 1959 235 1/2 ton 4 speed with 15 inch tires has anybody done this gear swap and found a speedometer gear that is right or close to right? I did a search and could not come up with any results. Thanks Steve
Call your local speedometer repair shop, they can make an adapter for you or you can find them online.
If you had a 390 rear and the calibration was right you'll need an adapter that speeds the cable up by 10% or a +1.10 ratio.
Mike B smile
Mike Boteler
1956 Chevy 3100 Resto Rod
1952 Willys M38 Army Jeep
1983 Jeep CJ7 Laredo
1984 Jeep CJ7
Silver Spring, MD
Type "TCI speedometer gear calculator" in the search box and just plug in the info from your truck. They also sell the drive and driven speedo gears.
Evan
Thanks for that info on that question. I will give that TCI site a shot . Thanks again.
Some of us have a fair sized stash of ratio adapters, when you figure out the ratio you need post it, might get a free one.
BC
1960 C60 pasture art
Hi Steve,
Where did you get the 3:55 gear set from. Is your rear end still original? I have a 57 1/2 ton and all I find is the 3:38 gear set.
Mark
Mark, My mistake they are 338 gears in original rear sorry for the wrong info. Gears and install kit came from Yukon Gear.
