0 members (),
108
0
Mod | | | Forums66 Topics128,115 Posts1,056,292 Members48,439 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Mar 2011 Posts: 85 'Bolter | | 'Bolter Joined: Mar 2011 Posts: 85 | Hi I installed a 338 gear set in the original rear. The truck is a 1959 235 1/2 ton 4 speed with 15 inch tires has anybody done this gear swap and found a speedometer gear that is right or close to right? I did a search and could not come up with any results. Thanks Steve
| | | | | Joined: Mar 2004 Posts: 6,214 'Bolter | | 'Bolter Joined: Mar 2004 Posts: 6,214 | Call your local speedometer repair shop, they can make an adapter for you or you can find them online. If you had a 390 rear and the calibration was right you'll need an adapter that speeds the cable up by 10% or a +1.10 ratio. Mike B  | | | | | Joined: Apr 2005 Posts: 2,832 'Bolter | | 'Bolter Joined: Apr 2005 Posts: 2,832 | Type "TCI speedometer gear calculator" in the search box and just plug in the info from your truck. They also sell the drive and driven speedo gears.
Evan
| | | | | Joined: Mar 2011 Posts: 85 'Bolter | | 'Bolter Joined: Mar 2011 Posts: 85 | Thanks for that info on that question. I will give that TCI site a shot . Thanks again. | | | | | Joined: Sep 2011 Posts: 1,456 'Bolter | | 'Bolter Joined: Sep 2011 Posts: 1,456 | Some of us have a fair sized stash of ratio adapters, when you figure out the ratio you need post it, might get a free one.
BC 1960 Chevy C10 driver 261 T5 4.10 dana 44 power loc 1949 GMC 250 project in waiting 1960 C60 pasture art Retired GM dealer tech. 1980 - 2022 | | | | | Joined: Jan 2019 Posts: 74 'Bolter | | 'Bolter Joined: Jan 2019 Posts: 74 | Hi Steve,
Where did you get the 3:55 gear set from. Is your rear end still original? I have a 57 1/2 ton and all I find is the 3:38 gear set.
Mark
| | | | | Joined: Mar 2011 Posts: 85 'Bolter | | 'Bolter Joined: Mar 2011 Posts: 85 | Mark, My mistake they are 338 gears in original rear sorry for the wrong info. Gears and install kit came from Yukon Gear.
