7 members (LAROKE, Stovebolt48, Tronman, Bwana-Jim, Otto Skorzeny, Lightholder's Dad, 1 invisible),
72
Mod | | | Forums66 Topics128,042 Posts1,055,511 Members48,424 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Feb 2013 Posts: 250 'Bolter | | 'Bolter Joined: Feb 2013 Posts: 250 | On the drivers side latch for my '48 GMC with exterior pull down door handle. One thing leads to another. I purchased new door panels for 'Speedy', pulled the interior door handle and window crank and removed the old panel. I saw that the relay was adjusted improperly which explained why I could never lock the door. Easy enough to adjust and the lock now works correctly and smoothly.
However, now--for the first time--the outside door handle doesn't work! It moves just a little bit but feels as if the lock is engaged and doesn't move far enough to trip the latch. With the window rolled down I looked at the latch from the top and could see that the outside handle is attached to the latch and does turn a little bit before it stops. I tried it both locked and unlocked by the relay but it feels exactly the same either way.
I did a search but didn't find any specific information for this problem. A couple of you guys talked about taking a latch apart and rebuilding it but I'm mystified about how to do that. I don't have a clue about how you did that! Looks like I'd be prying on things and hurting myself when the tool inevitably slips. I seem to remember seeing a good explanation of how the latches work, with pictures, but I'm unable to find it. There is a good tech tip article here on Stovebolt regarding the latches but I'm not getting the info I'm looking for.
Any ideas about a solution for this problem? Where can I look for more information?
Thanks, Jim | | | | | Joined: Sep 2006 Posts: 3,596 'Bolter | | 'Bolter Joined: Sep 2006 Posts: 3,596 | | | | | | Joined: Feb 2013 Posts: 250 'Bolter | | 'Bolter Joined: Feb 2013 Posts: 250 | Thank you Brad, the first link you provide, '1948 Servicing Truck Cabs', is what I had seen but not remembered the source. I got a couple of parts latches from Jerry Rivers so maybe between them and the one on my truck I can figure a way to make one of them work. I'll start by re-adjusting the relay for the lock. It might be that I adjusted it too far and somehow that affected the function of the outside handle. I'm still hoping someone has fixed the same problem I'm experiencing and knows what I need to do! | | |
