4 members (KEVINSKI, Nick in Manitou, FishinToms53, mick53), 74 guests, and 2 robots.
Topics128,126
Posts1,056,353
Members48,441
I have a question to the group. I have a 1950 Stovebolt with a 235 4 speed that was installed by PO. I have to replace the front bearing retainer because it is broken. Because the retainer is broke the transmission leaks a major amount of 90w oil. It looks like the PO welded the U-joint on the front torque tube in place. I really don’t want to pull the engine to replace the retainer but does anyone have any ideas. I thought I would drop the torque tube - and pull the transmission back enough to replace the retainer. Now I don’t know what to do... please help...
Help removing the torque tube.
“When I die, I want to die like my grandfather who died peacefully in his sleep. Not screaming like all the passengers in his wagon.” Abe Lincoln.
1950 Chevy Truck 3100
1958 MGA 1500
2014 Audi Q5
3B Offline
Hy Suddock, welcome, I'm not sure I understand what you are dealing with, can you not slide the driveshaft yoke back away from the transmission enough to let the driveshaft drop or move up away from the back of the transmission?
Remove the rear spring U bolts and slide the complete rear end assembly back on the springs until the U joint disengages. Then acquire the correct universal joint before you reassemble the job. There are supposed to be bolts holding the front and rear sections of the U joint together, not the Rube Goldberg mess you've got there!
The PO sure didn't do you any favor by welding the u-joint. Not sure if you can get enough clearance to get the driveshaft free but try this. Make sue you have the truck blocked on the frame, not by the rear end. Use whatever strapping affair you can devise to pull the rear end rearwards on it's pivots. The rear end may be able to be pulled far enough back to free the driveshaft or at least give you more access.
That u-joint looks like a u-joint that is used in a 3/4 ton truck.
Is your truck a 3/4 ton ?
I agree with Hotrod Lincoln, unbolt the u-bolts from the axle housing and slide the axle housing back until the
torque tube clears the u-joint rear yoke.
Once the the torque tube is out of the way.
You should be able to run a socket with a extension, inside the rear yoke to unbolt the front yoke from the main output shaft.
I agree with sliding the whole axle assembly to the rear on the springs.
Make sure you support the front of the torque tube so it does not drop when everything comes apart. I suggest you put a jack under it that you can slide to the rear as you move the axle. That front end is heavier than some people can easily support
Rusty
Thank you all for your responses. I am going to try them all until something works. I appreciate all your help. You have me headed in the right direction.
1958 MGA 1500
2014 Audi Q5
Does anyone out there have a schematic showing the proper assembly of the torque tube? Specifically the rear end of the tube where the carrier is.
ODSS Lawman
ODSS Lawman
Which part are you asking about? The pinion and shaft installation, carrier assembly, or carrier installation.
Either way you could use this:
3:55 Tech Tip
SWEET
1950 GMC 450
1951 Chevy 1/2-Ton
The GreenMachine
You are on the right track, but mine is a bit different. That showed a full length torque tube, my torque tube is only about 30" long, it stops at a frame cross member and is supported there. It then changes to an open drive shaft. My concern is the assembly right at the end of the torque tube where it is supported to the cross member. The order of the assembly of the bearing, seal, and a disc of some kind under the yoke is my concern.
2 piece driveshaft? I don’t think you have a 3100. How many lug nuts on the rear wheels? It would help us to know exactly what model you are working on.
3600, 8 lugs, 3/4 ton
Here is 3/4 ton torque tube (Front propeller shaft) rebuild photo album.
https://pbase.com/dennygraham/driveline&page=all
Front propeller shaft illustration
http://chevy.oldcarmanualproject.com/shop/1948_51truck/51ctsm0452.htm
Attached is front enclosed propeller shaft and rear open propeller shaft parts for 3600 3/4 ton truck.
xfiles
Thanks, this is a great help
Thank you all. I was able to replace the retainer with all your help. I tried to just pull the rear axle back but I finally removed the u-bolts on the rear springs and pulled the axle back and replaced the retainer. I didn’t have the correct universal joint so I put the welded one back in. I am going to be the bad PO in about 20 years.
1958 MGA 1500
2014 Audi Q5
