2 members (Hotrod Lincoln, Gray_Ghost), 95 guests, and 0 robots.
Topics128,051
Posts1,055,732
#1360176 05/13/2020 10:34 PM
does anyone know what front wheel offset is need for a 1951 3/4 ton pickup so the wheel
does not rub the tier rod end?
1 Offline
0 offset will clear the tie rod. The originals, at least on my 1-ton were set inboard about 1/2 inch. I can't remember if that equals plus or minus 1/2 inch but it's inboard. 3/4-tons had 17" wheels as an RPO they are the same wheels as a 1-ton. If you get wheels that are set outboard more than 0" it negatively affects steering. Makes it hard to keep it going straight in ruts.
1951 3800 1-ton
In the DITY Gallery
Positive offset is when the wheel mounting surface is outboard of the centerline of the rim. Negative offset is when the wheel mounting surface is inboard of the centerline of the rim, as in deep dish wheels.
