2 members (Hotrod Lincoln, greenie-reddy), 96 guests, and 2 robots.
Topics128,049
Posts1,055,741
#1360105 05/13/2020 1:56 PM
Here's the stupidest question ever posted. Is there an easy way to remove the stickers that are plastered all on all of the body panels that I buy. I soaked one in acetone yesterday and it didn't help much. I imagine that lacquer thinner would probably remove the black coating on them? Just a pain in the neck.
Mike Burns
1940 Chev 1/2 ton
1953 Chev 1/2 ton
1950 Studebaker Starlight Coupe
1947 Indian Chief
1943 Indian 741
Your wife’s hair dryer.🛠
great, never even thought of that. Thanks
Mike Burns
1940 Chev 1/2 ton
1953 Chev 1/2 ton
1947 Indian Chief
1943 Indian 741
What Martin said, and then with what little adhesive may be left I've used WD40 to remove it..............
Ron - - Dusty53
1954 Chevy 3604
I had to buy a heat gun to avoid repercussions from taking the wife's hair dryer out to the garage. wink
But on the plus side, it's another tool! grin
Thanks guys, I never had thought about using heat. I already have a heat gun, so I'll get to work tomorrow getting these stickers off.
Mike Burns
1940 Chev 1/2 ton
1953 Chev 1/2 ton
1947 Indian Chief
1943 Indian 741
never, Never, NEVER use WD40 or Amorall or ANY silicone spray on anything that will be painted; it's uncontrolled fish eyes if you do. Heat guns don't cause fish eyes.
Evan
Coilover is correct . Never, ever use any product containing Silicone on any surface you intend to paint. I should have been more specific and stated standard WD40. Standard WD40 does not contain silicone. They do offer a product "WD40 Specialist Spray" that does contain SIlicone and clearly says so. I have used standard WD40 to remove residual adhesives that are often left on the surface after using heat to remove stickers or labels, without issues. I follow up by cleaning the surface using Alcohol 70/30 water mixture.
"Norm Larsen, founder of Rocket Chemical Company, is considered the original founder of WD-40," according to wd40.com. ... WD-40 does not contain fish oil, contrary to a popular myth, nor does it contain silicone, kerosene, water, wax, graphite, chlorofluorocarbons (CFCs)."
Ron - - Dusty53
1954 Chevy 3604
Thank you, Dusty53
Original WD-040 (still available) does not contain silicone.
There is a WD-40 Silicone spray - guess what it contains?
If you ever plan to paint your vehicle, read slowly and carefully the warning in Evan's (coilover's) post above.
Naphtha (lighter fluid) is also a good solvent for sticker removal. It should be fish eye friendly.
Yep,
I use wax and grease remover, a solvent specifically sold for painting use.
I have used Goo Gone in the past...have had success with it.
I did the same thing but had to use my wife's curling iron...what a sticky mess. I quickly put it back in the drawer. When she found it I told her that she apparently laid it on the cotton ball bag while it was still hot...she actually bought that!
OOOOH! Hopefully she doesn't know your password here. eek
But your secret is safe with us. wink
