8 members (Peggy M, DaveV, 2-Ton, TUTS 59, JW51, walter74, moparguy, 1 invisible), 159 guests, and 1 robot.
Topics128,081
Posts1,055,955
Members48,430
Apprentice
Apprentice
I posted in the general discussion forum but so far no response so I thought maybe someone here has experience with this. I bought a key lock and added it to the drivers door on my 49. There seems to be an important part missing from the internal door latch mechanism as the keylock does not lock or unlock the door. I looked at the passenger lock and there appears to be another piece on it that is not on the drivers lock. Has anyone done this and can enlighten me on what they did to make it work? Thanks.
I've been told they never had a keylock on the driver side.Just the passenger side so thats probably why the latch isn't there. This might be wives tale but the reason for no lock on the driver side is the roads in those days wern't paved or in bad shape that most people went out the passenger side so they would not get muddy anyone else heard about this tale!!!!!!!! Peter
Hi Peter,i se you're another Canadian.Yes I've heard that story and will add to it.As a safety issue, in town where poeple wanted to lock the car they had to go out the righthand door away from the traffic
actually cars had locks on both side, it was just the cheap work trucks that got the single lock grin
Cars also had the key lock only on the drivers side in the 1930s.
Now I'm really confused grin
thats what i heard also,,,it was a safety issue,,lock it from the inside and get out on the pass side.
bc52 Being canadians we are always right and the other guys are wrong!!! Our stories make for good conversation!!!!!!!!! Even delux54 agrees Peter
grin grin grin
I was wondering can you get a kit to switch it ,so you can have a drivers lock?
Lothar(also from Langley,BC)
My 41 Plymouth Business Coupe had the door lock on the right only. Had to lock the left door from the inside. Most 40 models were like this and same for the AD trucks.
My truck is a 52 with pushbutton handles.New locks are made for them.I put one in each door[same key]
I have a 53 but my doors have been changed and they have the turn down handles.Do they have a kit for those?
Sorry Killer,I don't know.Hot Rod Corner or Old Car Centre in Langley might help
