3 members (Guitplayer, Danielbolt, Hotrod Lincoln), 79 guests, and 1 robot.
Topics128,154
Posts1,056,838
Members48,456
TKM
Offline
Can anyone tell me what is the proper transmission oil for my 1949 Chevy 3600 four-speed? Also, transmission seems to work well but the gearshift is very sloppy. Are there any rebuild kits that can address the sloppiness? Thanks! Tim
The '48-'51 Chevy Truck Shop Manual lists on page 0-5 the recommended lubricant as 90 wt. I prefer Red Line Oil MT-90, as it is synchronizer friendly, and works well in older transmissions.
Others can probably help better than I on the questions regarding shifter sloppiness.
Doug
1947 2nd-Series GMC FC152 3/4-ton
Follow the story in the DITY
1953 Chevy Bel Air Sport Coupe Powerglide
From Novak's website:
"When filling your 420 with gear oil, we recommend that you select a conventional mineral oil or a para-synthetic in lieu of a full synthetic oil. Properly assembled manual gearboxes do not have the thermal strains seen by combustion engines or hypoid gears. Synthetic fluid in these gearboxes, while not harmful, is probably an economic waste.
Hypoid gear oil is sulphurized higher than transmission oil and can be mildly corrosive to the non-ferrous alloys used for synchros, bushings and thrust washers in these transmissions.
An 80W-90, API-GL5 or MT-1 rated fluid is very good. Some claim faster shifts from using a 50W engine oil in their transmission and we do not consider this to be contraindicated unless you operate your vehicle in a very warm environment."
TKM
Offline
Hey guys, thanks so much for your help and advice, always like to hear from those with experience !
Previous posts have recommended - Traveller Ford Tractor All Mineral 90 Transmission Fluid, 2 gal.
SKU: 80660099 at Tractor Supply. $23.
Ron - - Dusty53
1954 Chevy 3604
Tim, I have to respectfully disagree with the recommendation of using GL-5 fluids for transmissions. The added Sulphur needed to make the GL-5 rating is generally corrosive to synchronizers, and any brass/bronze components, and not needed for other than hypoid rear ends and similar. A good GL-4 fluid is sufficient and synchronizer friendly. Further, fluids that are properly designed for transmission use have the right characteristics that promote smooth shifts. A typical GL-5 gear lube that is great for rear ends doesn't necessarily meet that, either.
Now, I'm not pushing the brand, as there are many choices, but here is a good white paper on the subject, FYI. Red Line MTL and MT-90 Tech Info.
Cheers!
Doug
TKM
Offline
Doug, I will check out the article, thanks so much for taking time to help, I’m amazed at all the knowledge on this site !!
