| | | Forums66 Topics128,162 Posts1,056,945 Members48,458 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Sep 2019 Posts: 64 'Bolter | | 'Bolter Joined: Sep 2019 Posts: 64 | Can anyone tell me what is the proper transmission oil for my 1949 Chevy 3600 four-speed? Also, transmission seems to work well but the gearshift is very sloppy. Are there any rebuild kits that can address the sloppiness? Thanks! Tim | | | | | Joined: Aug 2018 Posts: 351 'Bolter | | 'Bolter Joined: Aug 2018 Posts: 351 | The '48-'51 Chevy Truck Shop Manual lists on page 0-5 the recommended lubricant as 90 wt. I prefer Red Line Oil MT-90, as it is synchronizer friendly, and works well in older transmissions. Others can probably help better than I on the questions regarding shifter sloppiness. Doug
| | | | | Joined: Sep 2001 Posts: 29,270 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,270 | From Novak's website: "When filling your 420 with gear oil, we recommend that you select a conventional mineral oil or a para-synthetic in lieu of a full synthetic oil. Properly assembled manual gearboxes do not have the thermal strains seen by combustion engines or hypoid gears. Synthetic fluid in these gearboxes, while not harmful, is probably an economic waste.
Hypoid gear oil is sulphurized higher than transmission oil and can be mildly corrosive to the non-ferrous alloys used for synchros, bushings and thrust washers in these transmissions.
An 80W-90, API-GL5 or MT-1 rated fluid is very good. Some claim faster shifts from using a 50W engine oil in their transmission and we do not consider this to be contraindicated unless you operate your vehicle in a very warm environment." | | | | | Joined: Sep 2019 Posts: 64 'Bolter | | 'Bolter Joined: Sep 2019 Posts: 64 | Hey guys, thanks so much for your help and advice, always like to hear from those with experience ! | | | | | Joined: Jul 2014 Posts: 1,291 Moderator for Tons o' Fun , Co-Moderator Driveline Forum | | Moderator for Tons o' Fun , Co-Moderator Driveline Forum Joined: Jul 2014 Posts: 1,291 | Previous posts have recommended - Traveller Ford Tractor All Mineral 90 Transmission Fluid, 2 gal. SKU: 80660099 at Tractor Supply. $23.
Ron - - Dusty53 1954 Chevy 3604In the Gallery Forum "You can't dance with the Devil and then wonder why you're still in Hell." "They will forget what you've said, and they will forget what you have done but they will never forget the way you made them feel." | | | | | Joined: Aug 2018 Posts: 351 'Bolter | | 'Bolter Joined: Aug 2018 Posts: 351 | Tim, I have to respectfully disagree with the recommendation of using GL-5 fluids for transmissions. The added Sulphur needed to make the GL-5 rating is generally corrosive to synchronizers, and any brass/bronze components, and not needed for other than hypoid rear ends and similar. A good GL-4 fluid is sufficient and synchronizer friendly. Further, fluids that are properly designed for transmission use have the right characteristics that promote smooth shifts. A typical GL-5 gear lube that is great for rear ends doesn't necessarily meet that, either. Now, I'm not pushing the brand, as there are many choices, but here is a good white paper on the subject, FYI. Red Line MTL and MT-90 Tech Info. Cheers! Doug
| | | | | Joined: Sep 2019 Posts: 64 'Bolter | | 'Bolter Joined: Sep 2019 Posts: 64 | Doug, I will check out the article, thanks so much for taking time to help, I’m amazed at all the knowledge on this site !! | | |
