4 members (55shaker, 78buckshot, Otto Skorzeny, Charles in CA), 164 guests, and 8 robots.
Topics128,078
Posts1,056,031
Members48,433
#1359084 05/07/2020 2:59 PM
What or who's rear-end can I or should I replaced mu trucks rear with. It will not be for speed just to cruise with. I've been told a S10 with 50" plate to plate space.
jeeper #1359089 05/07/2020 3:17 PM
It's not all that easy. Be aware when you replace the rear end in a closed drive truck you also have to replace the transmission and find a driveshaft to fit the new conversion. Another issue is the wheel bolt pattern, your 54 has a 6 lug pattern. Car and small trucks use a 5 lug pattern except S-10 4x4's. In addition the spring pads have to be re-positioned to match your existing configuration. Other things to consider are brake cables and lines. Some fabrication skills are involved and of course $$.
Fred
jeeper #1359096 05/07/2020 3:49 PM
I can cruise all day at 65 MPH in my 1954 Suburban.
Lower RPM installing 3.90 to 3.55 Ring & Pinion conversion (you will need a 4.11 rear-end R&P ring carrier).
Buy/use an installation kit - your drive-line noise will noticeably decrease.
Radial truck tires on the original 16" wheels (gets a wider diameter that results in lower RPM.
No matter what you do:
- check and adjust all brake system parts
- check and adjust all front suspension parts
- check all front/rear sdpring attachment points
rfs56trk #1359412 05/09/2020 10:13 PM
Tks, will start to look for S10 4x4. In the 93-2002 years??
jeeper #1359422 05/09/2020 11:01 PM
This has confused me. I have a 54 3/4 ton and it has an open drive line. I think it's stock?
jeeper #1359424 05/09/2020 11:06 PM
That is correct.
1954 was the first year for an open driveshaft in the 3600.
1954 was the last year for an enclosed driveshaft in a 3100.
jeeper #1359434 05/10/2020 12:13 AM
I have a 1979 Nova with 2.73 gears with a T5 trans in 54 235.. Works well in flat land and so so in the Smokie Mountains.
Ron, The Computer Greek
I love therefore I am.
1954 3100 Chevy truck
2017 Buick Encore
See more pix
That is correct.
Thank you for that. I have been confused about that since the first time I looked through the optional see through bed.
jeeper #1359520 05/10/2020 1:03 PM
The 2003-2012 Chevy Colorado had 6x5.5 bolt pattern. They had the same width rearend as the S10.
1954 3600 Chevy Truck
"The Fake Truck"
More pix on Photobucket
jeeper #1359822 05/11/2020 7:31 PM
I have a lead on the front of a mustang 11; any suggestions on this for the 3100 1954 truck
Whitedog #1359823 05/11/2020 7:33 PM
Good to know. on the Colorado
jeeper #1359889 05/12/2020 2:39 AM
Crusing in the Passing Lane
4wd S-10's have 2" wider rear axle than 2wd.
Ed
