4 members (NJC, Oswald, 2 invisible),
132
Mod | | | Forums66 Topics128,081 Posts1,055,955 Members48,430 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Sep 2003 Posts: 1,820 Shop Shark | | Shop Shark Joined: Sep 2003 Posts: 1,820 | is this? I have a Schiefer aluminum flywheel in my 37 pick up and just recently installed a T-5 with an Astro clutch. I pulled the flywheel cover just to look at things and I have a dusting of aluminum all around the inside of the flywheel cover. It's like the clutch is grinding away the flywheel! This is something I'm not familiar with! Does anyone have an idea what is going on here?  :confused: Joe
"Truckin' Around .......... Since 1937!" My name is Joe and I am addicted to Classic Country Music. I just can't hep myself.Operators are standing by to take your calls! Now cruising in the Passing Lane | | | | | Joined: Dec 2004 Posts: 1,897 Shop Shark | | Shop Shark Joined: Dec 2004 Posts: 1,897 | Aluminum is softer than steel. It is quite possible the clutch is doing what you say. May be there is a speacial clutch make up to minimize the wear on the flywheel??? | | | | | Joined: Apr 2005 Posts: 641 Shop Shark | | Shop Shark Joined: Apr 2005 Posts: 641 | mayby something is scraping the flywheel or starter gear ware | | | | | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | I vote for the starter scuffing the ring gear
Bill | | | | | Joined: Mar 2005 Posts: 1,029 Member | | Member Joined: Mar 2005 Posts: 1,029 | The aluminum flywheel that I had years ago had a bronze looking clutch surface with an iron ring gear. I guess that isn't the case here. | | | | | Joined: Jul 2004 Posts: 5,708 'Bolter | | 'Bolter Joined: Jul 2004 Posts: 5,708 | I was curious about the friction surface too. If you do a search on Schiefer flywheels, it mentions how the area in contact with the clutch disc was sprayed with a metal/bronze coating.
Without some durable overlay, I think the aluminum flywheel would be toast in a few miles.
Stuart | | | | | Joined: Mar 2005 Posts: 637 Shop Shark | | Shop Shark Joined: Mar 2005 Posts: 637 | I have an aluminum flywheel that has an insert of steel for the clutch wearing surface. | | | | | Joined: Jul 2006 Posts: 23 Junior Member | | Junior Member Joined: Jul 2006 Posts: 23 | Is your Driven disc a larger diameter than the ware surface on the flywheel? | | | | | Joined: Sep 2003 Posts: 1,820 Shop Shark | | Shop Shark Joined: Sep 2003 Posts: 1,820 | The clutch that I did have in the truck was a 10 1/4". I never had the dusting of aluminum with that first clutch. The new one is a 9 7/8". I don't see how that could make any difference, but something has changed. I have checked everything and I see no eveidence of anything scraping or scratching the flywheel. :confused: Joe
"Truckin' Around .......... Since 1937!" My name is Joe and I am addicted to Classic Country Music. I just can't hep myself.Operators are standing by to take your calls! Now cruising in the Passing Lane | | | | | Joined: Sep 2003 Posts: 1,820 Shop Shark | | Shop Shark Joined: Sep 2003 Posts: 1,820 | Well, I still haven't pulled the T-5 to see what the heck is up yet, but have re-thought what has been done.
It appears that I used the wrong clutch disc when I converted to the T-5 transmission. Instead of using the RC4212 11" disc, I used the RC4201 9 7/8" disc. In so doing, the current disc is not large enough to work the insert of the aluminum flywheel and is working on the inner area of aluminum only. Within the next few weeks, this will be confirmed, but it is almost certain that is what is happening.
Rule: You must know exactly what you are doing!
Joe :confused_smile:
"Truckin' Around .......... Since 1937!" My name is Joe and I am addicted to Classic Country Music. I just can't hep myself.Operators are standing by to take your calls! Now cruising in the Passing Lane | | | | | Joined: Aug 2007 Posts: 1,859 Grumpy old guy playing with trucks, cars, and boats | | Grumpy old guy playing with trucks, cars, and boats Joined: Aug 2007 Posts: 1,859 | Always use a steel wear surface on aluminum flywheels for the street.
