6 members (Otto Skorzeny, Joe H, Gdads51, Rusted Nut, fonz8261, 1 invisible), 205 guests, and 9 robots.
Topics128,074
Posts1,055,999
Members48,433
#135847 10/26/2006 3:58 PM
I'm lookin to transplant my 46 torque tube with a later open drive pumpkin, ala Steppemwood's tech tip. I know he used a 55 truck rear for his but will one from a car work also?
I have a line on a 57 car rear end, does anyone know if the innards of a this rear end will fit into my rear axel?
George
#135848 10/26/2006 4:56 PM
George -
A car rear axle innards, any year, will not fit into you housing, however a 57 car rear end will bolt up nicely under your truck.
Joe smile
#135849 10/26/2006 7:36 PM
Thanks, Joe That's what I thougt.
#135850 10/27/2006 11:57 PM
do a search on rear ends
http://www.stovebolt.com/bboard/cgi-bin//ultimatebb.cgi?ubb=get_topic;f=2;t=012492;p=1#000004
http://www.stovebolt.com/bboard/cgi-bin//ultimatebb.cgi?ubb=get_topic;f=2;t=011096#000000
http://www.stovebolt.com/bboard/cgi-bin//ultimatebb.cgi?ubb=get_topic;f=2;t=012300#000000
http://www.stovebolt.com/bboard/cgi-bin//ultimatebb.cgi?ubb=get_topic;f=2;t=011579#000000
Want to know about swapping out a rear end.
and what to use Here's food for thought.... on 50’s chevy’s By: Jim Forbes
The 82-newer Camaros are wider than the older ones, so you should stick with the 70-81 models. The 75-79 Nova uses the same rear as these older Camaros, I believe. The 68-74 Nova chassis is the same as a 67-69 Camaro; the 75-79 Nova chassis is the same as the 70-81 Camaro. The 82-newer Camaros used the small 7.5" rear-end design that the 78-newer Malibu/Monte Carlo/regal/cutlass etc used, but it's quite a bit wider. Some of the 82-newer Camaros used different rear ends, such as the Dana 44, and some weird Australian rear-end. Of course, if you want to make sure, get out your tape measure and check yourself! I may be wrong.
Here's another one from Jim on the subject---- There are lots of rear ends available! Some fit better than others. For 6 lug rear ends, the 64-69 1/2 ton 2wd Chevy (and some GMC) trucks have a 12 bolt rear, about 60-61" wide (I measure them where the wheels bolt on). The 70 2wd and 70-81 4wd have a 6 lug 12 bolt that is a couple inches wider, but will fit under an Advanced Design or Task Force truck as long as you don't get too wild with wheel/tire width. The heavy duty models have a 2.75’’ brake shoe, that’s stopping power. The 12 bolt truck rear ends from the 60s usually had 3.70 gears, which is a bit much for extended highway driving at 75 mph. You can swap the differential carrier and ring/pinion gears from a later TRUCK or VAN 12 bolt, the 70s trucks usually had 3.08 or 3.40 gears. Of course, you'll need to know how to set up ring/pinion gears, bearing preload, and all that other neat stuff to do this. These 60s truck 12 bolt rear ends are from coil spring trucks, so the perches are in the wrong place, and they have some extra stuff on the housing for a panhard bar, which you won't need with leaf springs. Most 60s GMC trucks, and some Chevys, had Dana 44 or Dana 60 rear ends, and leaf springs. These rear ends are 6 lug, about 60" wide, and will bolt into a Task Force truck (with some fudging, the perches are about 1/2" too far apart). The brakes use different parking brake cables, which is a problem, and the drums have a different offset. Gear ratios range from 3.21 to 3.92 normally, the 3.21 is found behind some GMC V-6 engines, and is a nice ratio for an old truck. The Dana 44 uses a standard Chevy 1310 yoke, but the Dana 60 uses a heavy duty yoke, which takes a larger 1350 series ujoint. A similar Dana 40 rear-end was available as an option in 59 Chevy trucks, equipped with positraction...rare, and with a 3.92 ratio. I have one of these rear ends; it was in my extended cab truck...I'm saving it for when I build a race truck (one of these years).
The 71 and newer 2wd trucks use a 5 lug 5" bolt pattern, same as the 71-76 full size cars. There is not much available in the way of matching front brake rotors that will fit an old truck, so this rear-end is not too popular a swap, unless you get the 70-up 4wd 6 lug axles. Chevy also used 10 or 12 bolt rear ends in lots of cars, in varying widths. The heavy duty models have a 2.75’’ brake shoe. A common one is the 61" wide 70s vintage Camaro/Chevelle/Nova (and clones) 8.5" rear-end. In Camaros/Novas it has leaf springs, but the perches won't work with old truck springs. In Chevelles, it has coil springs, with lots of extra brackets to cut off, and the cast in mounting "eyes" on top, where the upper control arm bushings fit. Wheel bolt pattern is 4.75", and there are front disk brake kits available to match, or you can use the 53-54 car front hubs/drums on the original 50s truck brakes, to get the same bolt pattern front/rear. This is a good rear-end for using in an old truck, the ratios are commonly 2.73-3.36, with higher gears available. The axle shafts are usually worn out in these things, so check them (pull the cover, lockpin, and C clips out to get them loose) where they ride in the wheel bearings...before buying the rear-end! The 55-57 Chevy car rear-end is almost a bolt in, the perches need to be relocated to the top of the housing though. It has the 4.75" bolt pattern, and ratios are usually 3.55-3.73, but sometimes you'll find a 3.36. The 78-88 mid size GM cars use a 7.5" 10 bolt, which is about 58/5" wide. This rear-end would work well in an early (older than 47) truck, but it is quite light duty. Ratios are usually 2.29-3.23, which means you want some torque in the engine to pull it...but rpm will be low. This is a coil spring rear-end, with all the mounting brackets that need to be cut off. The Ford 8" and 9" rear ends come in a whole bunch of varieties, and only a few are useful in oletrucks. The late 50s full size cars have a nice one, but it's not easy to find brake hardware, drum, etc anymore. The mid 60s midsize cars, such as the Fairlane, have a rear-end that is about the right width, and would be a good candidate...if you can find one. The Maverick/Granada is very narrow, about 56.5", and would not fit anything but a very early truck, or perhaps a tubbed Pro Street truck. The 60s full size Ford car rear ends are usually too wide, but if you find one, measure it and see! Most earlier full size, and all mid size, cars use the 4.5" bolt pattern, while later full size cars use the 5" pattern. The Ford trucks have a big 5 on 5.5" pattern, with a big center that takes some work to redrill to anything Chevy. Ratios range from 2.47 to 4.30, and the axles come in 28 or 31 spline varieties. There is lots of interchange possible with the 9" rear-end, which is why it's so popular...I have one in my 55 Belair, and in my 57 Suburban chassis. Unfortunately, they are getting expensive, especially when you have to shop around for just the right one that will fit. So...if you don't know if a rear-end will fit, or what it came from, get out your tape measure and see for yourself! The most important things are overall width, and wheel bolt pattern...then concern yourself with ratio. I like a 2.75-3.0 ratio for a V-8 powered truck that will spend lots of time on the highway; about 3.2-3.7 for a 6 cylinder or small V-8 for in town and limited highway use, and the stock 3.9-4.56 ratio is great if you have to use your truck to haul lotsa weight, and you don't have much engine...just don't plan on going much faster than 55!
Jim & Caroline
#135851 10/28/2006 5:20 AM
46forme,
I just finished the punkin swap and Steppenwoods expose demonstrates the ease of the proceedure very well. I have some photos of other processes of the swap if interested (posting of them pending new web site and some organization). I inquired about options on here and understand any 1/2 ton Chevy truck 3rd member from 55 to 62 will slip right in. Me, I found a 55 in the neighborhood with 3:90's. Kept stock brakes, axels, housing width, 6 lug wheels, etc. Bought the 2 1/2" u-bolts from a farm supply, etc. My opinion this is the way to go based on ease and cost. I am biased as today I finished a T-5 swap. Again all the above goes for it as well... photos, cudos to Steppenwood, etc.
I flew in here on the 15th and in 14 days have done a complete rear swap, t-5 instal,had drive shaft made, replaced bushings and shakles on the rear, gotten my wheels sandblasted, grew a beard and visited with my mom and dad!
This is all on a 46 as well.
Cavebull
cavebull
Stovebolts - so easy even a Cavebull can do it.
https://www.flickr.com/photos/dodsonbrett/collections
#135852 10/28/2006 8:25 PM
Cavebull, I already have a 55 pumpkin to put in my 1/2 ton 52Panel. The question I have for folks is what year chev had the 6 lug wheels. What I "want" or think I want, is the ones with the beauty ring and center cap with the little rectangular slots in the back of it. What years are these available, will they work on the front wheel without rubbing the tie rod. I think they will look cool on the panel.
#135853 10/28/2006 9:22 PM
On 2wd 6 lug was used up to '70, 4x4 stayed 6 lug to current models. The wheel that you are looking for is most likely the 4x4 Ralley wheel (Blazer Ralley) that was used from '73-'87 on trucks, to '91 on Blazer and Suburban. They should fit without rubbing. These are the ones that are on my '55, I'm running 'Vette trim rings and late model centercaps. The caps required special lug nuts, might not be easy to find them. http://rides.webshots.com/photo/2731701030092261295ROodmu
Bill Burmeister
#135854 10/29/2006 5:02 PM
longbox, that is the type I think I want to use. I am gathering info and printing it out as it may be summer before I actually need to round them up. I also remember from a few months back that someone mentioning that the Colorado's have 6 lugs but I really don't see any that I like for the panel and I think someone mentioned that those particular ones rubbed the tie rods unless you used an offset. Thanks for you info.
#135855 10/31/2006 2:49 AM
ODSS President
ODSS President
Nice work cavebull, nice truck longbox. I've done the TT out '57 3.90 in on my '49 with a .70 od I get 2.73 final drive with 215 85R 16's.
~ Cosmo
1949 Chevy Half Ton
