5 members (Bill Hanlon, MRMEROTH11, JW51, Mike Burns, KEVINSKI), 110 guests, and 2 robots.
Topics128,133
Posts1,056,396
Members48,441
Thought I would stop by to say hi and introduce myself. My name is John and I have a 1954 Mapleleaf truck that I am currently restoring.
This is the first truck I have attempted as my other vehicles that I have restored have been standard Australian cars. I wanted to get into something a little different. Boy have I! In Australia this beast sports the usual 54 front grill however a lot of other gear relates to the U.S 1952 version like the split windscreen, vacuum wipers, 6 volt system, ignition key and starter button,and the hand brake that comes up through the floor as a long handle. Oh and dual wheels at the rear.
She was a little bit out of the way which is why I probably got it so cheap (16hr round trip). She runs..now, I've removed and repaired rust from the floor pans and cab corners, shes had lots of bits purchased for replacement and ready for paint next week.
Can't wait to take my 5 yr old daughter for a ride she loves daddys' truck.
Great site, hope to chat soon,
regards
Dawso.
Welcome Dawso!
Sounds like you either have a 1 Ton or a Big Bolt (with dual rear wheels). We would love to see some pictures after you get some fresh paint sprayed!
Dave Baird
1951 Chevy 3803
Leo Offline
Moderator
Moderator
Welcome John, you mention it has US gear on it, Mapleleaf trucks were Canadian actually. Basically heavier Chevy trucks with GMC engines. I didn't know that they had split windshields that year though. Good that you have it running and tell your daughter she has good taste! Have fun.
Leo
Welcome John, you wont find a better forum as the Bolters here has a vast knowledge on these old trucks.
Welcome to the Bolt Dawso. Sounds like your well on your way to be coming a Stovebolt family. Your daughter will treasure the memories and hopefully the truck for a long long time. You'll find quite a few other bolters on your side of the pond. They'll find you soon!! Good luck and post some pics when you can.
Yes, from what I gather parts were shipped from Canada for assembly here, hence the right hand drive. Here they were called 54 because thats the grill they have however split windscreen indicates earlier model in the U.S. I bit of a bitsa.
Interesting the comments re GMC motor. I shall go to another section on Stovebolt forums to discuss.
Thanks for the warm welcome and help so far. Dawso.
Big thanks to Paul for sorting out my account after all this time away I appreciate it. 6 years I think.
Originally after fixing up my Australian built 54 Chev truck back up to scratch and looking pretty good. Unfortunately things got in the way and she sat in the yard for many years.
She is a little worse for wear now paint wise. Developed small easy-to-fix rust holes in the bottom of the front cab corners between the door and guard down underneath.
Looking forward to chatting and watching other vehicle builds here.
I only have to get a few bits together and then get stuck back into the work on it.
Welcome Back! maybe post some pix of your truck from down under... just remember to invert them, so they display correctly here (in the US).
Another quality post.
Real Trucks Rattle
Former Workshop Owner
Hello John, glad to have you back. thumbs_up
~ J Lucas
2006 GMC Envoy 4.2 I6
2023 Ram 2500/Cumins 6.7 I6
2002 Silverado 2500 Gas 6.0
1941 Chevy 1/2-Ton
1942 Chevy 1.5-Ton SWB
My Flicker Photos!
Welcome back. chug
Getting back to the re-build.
Just a photo of how it is now.
Looks like things are going well.....even 15 minutes a day will keep it moving along. Thanks for sharing.
Righty Tighty, Lefty Loosey
Welcome back!
Great news that you are getting back to work on the truck!
Yes, please post some pictures.
What are you planning to do to it? Full restoration or restomod?
If you are going to tackle the project hard on, consider keeping a project journal, either personally or here on the site, they seem to be very popular.
Happy wrenching,
Steve
1946 Chev 1/2 ton - 6V/+ground/Bias-ply original - shake/Rattle and Roll! (SOLD)
1940 Chev 1/2 ton Franken/Restomod
Hi Steve,
Thanks for the kind words.
I was considering the journal I do not think it was here years ago when I was on here but not sure if I would fit the criteria as I might be into it for two solid weeks then a few off. I was thinking of kicking off in the Big Bolt section and updating As frequently as I could.
Well, I had this truck back to looking near new. Pretty engine and engine bay, gloss red paint inside and out and only had the bed to do. Things happened and she sat out in the yard for about eight years now and looking pretty worse for wear as my clear coat has cracked and split apart as has the paint and it has deteriorated substantially. only getting small rust holes in the bottom front corners of the cab between the guard and door frame.
Looking forward to getting back into it I can tell you.
John.
Glad you're back at it! Keep chipping away at it.
1950 Chevrolet Model 1314
In Project Journals
keep in chipping.. maybe that will get me into the garage more often!
Real Trucks Rattle
Looking good.
~ J Lucas
1941 Chevy 1/2-Ton
My Flicker Photos!
