Brrrr
Winter is Coming
A good Tech Tip
WINTERIZING YOUR TRUCK
4 members (‘37ChevyPU, NJC, Maybellene, Peggy M), 109 guests, and 3 robots.
Topics128,277
Posts1,058,453
Members48,490
I purchased a front license plate mounting bracket from LMC for my ‘57 3200. I can’t figure out how to mount it. There is one unused hole in the front bumper but every picture I’ve seen of ‘57 trucks with front plate had it on top of bumper in front of grill. Any ideas, photos of your bracket, mounting holes, etc would be appreciated.
1957 Chevy 3200
Daily Driver
PS, A/C, Tilt column, Rebuilt 350, Rebuilt TH350, Reupholstered Bench Seat, sound proof/insulated, LED headlights/taillights/backup lights/interior courtesy lights.
Follow in the DITY
I don't have a 57 3200 but looking at these photos it looks like your bracket may mount to the sheet metal behind the bumper making the plate set just above the bumper. I'm sure someone else will have more knowledge of this than I do.
1949 5 Window 3100
Follow in the DITY
Veteran of the USAF
My Website
Thank you olezippi! The picture with the bumper off tells it all. I haven’t had my bumper off to see those holes. I plan to paint the truck this year, so I might have discovered the holes then, but previous owner could have filled them in. I’ll crawl under later today and see if they exist.
UPDATE: I crawled under and the holes are there. I added pic. Thanks again! This forum, you guys, are awesome.
UPDATE 2: I got the plate mounted. Picture added. Thanks again olezippi. I hope this post can help some other newbie.
1957 Chevy 3200
Daily Driver
Follow in the DITY
Looks good. Glad it worked out.
1949 5 Window 3100
Follow in the DITY
Veteran of the USAF
My Website
DES57
The FAM, Section 14, Sheet 2 shows that bracket & mounting. Ditto what Olezippi said and what you finally found
delky dave in WYO
1957, 3100, v8
2016 gmc 4wd
Thanks delky! I have a shop manual but I didn’t know there was a Factory Assembly Manual. I found it online and saved it to my ebooks. I found the section/sheet you referenced. I might purchase a paper copy someday.
1957 Chevy 3200
Daily Driver
Follow in the DITY
24601
24601
Thanks for the feedback, Des! Made my day (and its only 0712) smile
Thanks, everyone.
smile
~ John
1949 Chevrolet 3804
1973 IH 1310 Dump
1963 Kaiser M38A1
2014 Ford E-350 4x4 (Quigley)
