1 members (Bill Hanlon),
138
Mod | | | Forums66 Topics128,115 Posts1,056,288 Members48,439 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Apr 2003 Posts: 942 'Bolter | | 'Bolter Joined: Apr 2003 Posts: 942 | Looking to find out the correct level for Gear Oil in the Winch (Re-fill plug is on top of it).
Also would the regular 80W-90 GL-5 be the correct weight and type for it?
'60-'72 Chev/GMC Fan GMC 9500 Fan Detroit Diesel Fan
| | | | | Joined: Nov 2006 Posts: 247 'Bolter | | 'Bolter Joined: Nov 2006 Posts: 247 | I have 2 8ooo lb Ramsey winches on my 76 Century 401 model wrecker. The fill plug is about 1/3 of the way up from the bottom , and it states to use 140 weight gear oil on the cover. Could the cover been removed at one time and been put on upside down? The ones on my truck are hydraulic winches and not chain driven. Jim
| | | | | Joined: Apr 2003 Posts: 942 'Bolter | | 'Bolter Joined: Apr 2003 Posts: 942 | I've got an old '69 Model Holmes. The plug is on the top of the cast iron housing. The one I have does not have a cover with a plug in it. I looked for a spill-over plug, but did not see one anywhere.
| | | | | Joined: Jul 2004 Posts: 2,987 'Bolter | | 'Bolter Joined: Jul 2004 Posts: 2,987 | If Spanky doesn't check in soon, maybe send him a PM. He knows those things inside and out. | | |
