Labor Day
Labor Day
MORE wrenching?
Wrenching this Labor Day
Plenty of places to share.
5 members (Peggy M, baldeagle, NJC, Charles in CA, 1 invisible), 39 guests, and 3 robots.
Topics128,005
Posts1,055,254
Members48,418
#1357300 04/26/2020 9:32 PM
Ok! been looking over different pages, trying to decipher the info on the trans I recently received. I do know that it is a New Process, but, having problems figuring out what the preceding numbers should be,435,450, or 465. Cast housing, aluminum rectangle top, twin PTO ports. casting numbers on the case are C-91171,11X3XSPE, and AL, on the top is C-92802, hand brake attached to the case, and band brake on tail output. Any info is appreciated, before I try to stuff this into my '53 2 ton.
1953 Chevy Two-Ton
More pix on Photobucket
Be careful calling yourself a expert,because an "EX" is a hasbeen and a"SPERT" is a drip under pressure.
Here's what I found...
It's hard to match up model numbers with casting/part numbers, but I think I figured it out...
Case Casting C-91171 is a 1956 only Chevrolet Series 5, 6, 7 & 8 New Process 5-speed (direct drive). That would make it the NP-540 as it holds 10 pints of oil. The 1957 Series 5, 6, 7 & 8 NP 5-speed has case casting number 92116.
I ruled out the NP-435 as it only hold 7 pints per my MOTORS Manual and I can't find any Chevrolet NP truck transmissions that hold 7-pints...
I also ruled out the 465, as that number SM-465 is a corporate GM 4-speed transmission made in the Muncie Plant from 1968-up.
The cover number is a good number used from 1956 at least thru 1967 (exc. TILT).
You'll get one additional gear for better puling power, but you won't gain any speed going from the SM-420 to the NP-540.
Mike B smile
Mike Boteler
1956 Chevy 3100 Resto Rod
1952 Willys M38 Army Jeep
1983 Jeep CJ7 Laredo
1984 Jeep CJ7
Silver Spring, MD
Crusing in the Passing Lane
435's have 3 shift rails, 540 series have 4 shift rails, both have Al top covers, 465's have Ci top covers. 540's rarely come with OD gears, however, OD is obtained by using the third gear location, making for a large gap from 2nd to 4th., which is really awkward with a load.
Ed
Thanks guys! All information is greatly appreciated! The other number that I saw was NP 4500. Now, I know of the NV4500, and that's why I threw in the NP450 number.
1953 Chevy Two-Ton
