| | | Forums66 Topics128,022 Posts1,055,269 Members48,418 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Feb 2009 Posts: 400 'Bolter | | 'Bolter Joined: Feb 2009 Posts: 400 | Ok! been looking over different pages, trying to decipher the info on the trans I recently received. I do know that it is a New Process, but, having problems figuring out what the preceding numbers should be,435,450, or 465. Cast housing, aluminum rectangle top, twin PTO ports. casting numbers on the case are C-91171,11X3XSPE, and AL, on the top is C-92802, hand brake attached to the case, and band brake on tail output. Any info is appreciated, before I try to stuff this into my '53 2 ton. | | | | | Joined: Mar 2004 Posts: 6,212 'Bolter | | 'Bolter Joined: Mar 2004 Posts: 6,212 | Here's what I found... It's hard to match up model numbers with casting/part numbers, but I think I figured it out... Case Casting C-91171 is a 1956 only Chevrolet Series 5, 6, 7 & 8 New Process 5-speed (direct drive). That would make it the NP-540 as it holds 10 pints of oil. The 1957 Series 5, 6, 7 & 8 NP 5-speed has case casting number 92116. I ruled out the NP-435 as it only hold 7 pints per my MOTORS Manual and I can't find any Chevrolet NP truck transmissions that hold 7-pints... I also ruled out the 465, as that number SM-465 is a corporate GM 4-speed transmission made in the Muncie Plant from 1968-up. The cover number is a good number used from 1956 at least thru 1967 (exc. TILT). You'll get one additional gear for better puling power, but you won't gain any speed going from the SM-420 to the NP-540. Mike B  | | | | | Joined: Jun 2011 Posts: 5,096 Crusing in the Passing Lane | | Crusing in the Passing Lane Joined: Jun 2011 Posts: 5,096 | 435's have 3 shift rails, 540 series have 4 shift rails, both have Al top covers, 465's have Ci top covers. 540's rarely come with OD gears, however, OD is obtained by using the third gear location, making for a large gap from 2nd to 4th., which is really awkward with a load.
Ed
| | | | | Joined: Feb 2009 Posts: 400 'Bolter | | 'Bolter Joined: Feb 2009 Posts: 400 | Thanks guys! All information is greatly appreciated! The other number that I saw was NP 4500. Now, I know of the NV4500, and that's why I threw in the NP450 number.
