0 members (),
151
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,089 Posts1,056,141 Members48,436 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jan 2020 Posts: 89 'Bolter | | 'Bolter Joined: Jan 2020 Posts: 89 | Hello. I need to replace the gas tank in my 1947 3100 it has a 1955.2nd 235 engine and I plan on using the original 1947 fuel gauge. I plan to buy a universal tank to install behind the rear axle. Most tanks say they don’t accept the original sending unit. If I buy a sending unit P/N TAN-GME from tanks inc. GM to 1964 type 5 hole -0-30 ohms would that work with the original gauge? | | | | | Joined: Nov 2005 Posts: 6,100 'Bolter | | 'Bolter Joined: Nov 2005 Posts: 6,100 | Hy 47 BOMBER, yes that sender should work with your original gauge. | | | | | Joined: Jan 2020 Posts: 89 'Bolter | | 'Bolter Joined: Jan 2020 Posts: 89 | | | | | | Joined: Jan 2002 Posts: 2,839 'Bolter | | 'Bolter Joined: Jan 2002 Posts: 2,839 | If you are replacing both tank and sending unit, I would seriously consider putting in exactly 1/4 tank of fuel, then the sending unit and see if your gauge reads 1/4 tank full. If not, remove unit and tweak the pivot arm of the unit. Be sure to pre test the float to ensure it doesn't have a leak.
Craig My '50 Chevy 3100 5 window, '62-235cu, 3:55 rear My truck ....... Respect The Rust If I'm not working on my truck, '65 m00stang or VW camper, I'm fishing with the wife or smoking Salmon.
