0 members (), 129 guests, and 3 robots.
Topics128,110
Posts1,056,241
Members48,437
#1357154 04/25/2020 11:55 PM
Hello. I need to replace the gas tank in my 1947 3100 it has a 1955.2nd 235 engine and I plan on using the original 1947 fuel gauge.
I plan to buy a universal tank to install behind the rear axle. Most tanks say they don’t accept the original sending unit.
If I buy a sending unit P/N TAN-GME from tanks inc. GM to 1964 type 5 hole -0-30 ohms would that work with the original gauge?
3B Offline
Hy 47 BOMBER, yes that sender should work with your original gauge.
Awesome thanks 3B.
If you are replacing both tank and sending unit, I would seriously consider putting in exactly 1/4 tank of fuel, then the sending unit and see if your gauge reads 1/4 tank full. If not, remove unit and tweak the pivot arm of the unit. Be sure to pre test the float to ensure it doesn't have a leak.
Craig
Thanks will do that.
