4 members (32Fordpuchoptop, ‘37ChevyPU, Otto Skorzeny, 2-Ton), 105 guests, and 2 robots.
Topics128,050
Posts1,055,675
#1356738 04/23/2020 2:17 PM
Getting ready to replace king pins in a ‘53 3100 and found that the top has no dust cover and the housing has been “pinged”. Would this indicate the king pins have been previously replaced and the top cover left off or was this a factory practice? It seems the pins will need to be knocked out from the top to the bottom but that will require the removal of the hub. Has anyone encountered this problem before and, if so, any suggestions? My last dealings with king pins was about 60 years ago on grandpa’s farm and then I was just a gofer and a watcher.
'53 3100 Short Bed
Texas Peace Officer - supporter of the Badge and the Blue Line
Pain is part of life, Misery is an option.
I think those plugs were/are called bearing plugs - they were supposed to to be seated and then staked at four points (on the outer-side edge)
Have you checked a Shop Manual?
Haven’t checked shop manual......but will do so.
'53 3100 Short Bed
I think you mean "peened", not "pinged". Peened as in hammered over like a rivet head, or staked as Tim said. Staking is done with a punch and hammer.
5ptstar #1356963 04/24/2020 10:58 PM
They 'ping' out Texas way.
You can push kingpins up or down. There is a way to use the weight of the truck to knock them out. I have done it before years ago , but don't remember how I did it. Hopefully someone with a better memory will come along shortly.
