| | | Forums66 Topics128,014 Posts1,055,324 Members48,419 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Sep 2019 Posts: 223 'Bolter | | 'Bolter Joined: Sep 2019 Posts: 223 | Can any of you bolters tell me what would be the widest, (and offset), rear wheels I can put on my '50 3100? Here's the parameters...I've installed an '81 Camaro 10 bolt. The interweb states that it's and inch wider than the original closed drive shaft...so doing public school math it's a half inch wider on each side. I don't want to cut the bed sides and tub the box. FYI, I have moved the shocks inboard which really doesn't come into play for what I'm wanting to do. I think at this time I want to use the same width on the front, just smaller diameter wheel, (20's rear, 18's front). Is there a way to measure for clearance, offset, other than using a gauge? | | | | | Joined: Oct 2005 Posts: 4,249 "Hey! I sound like Darth Vader!! | | "Hey! I sound like Darth Vader!! Joined: Oct 2005 Posts: 4,249 | Sure, a tape measure and a straight edge. | | | | | Joined: May 2005 Posts: 8,983 Sir Searchalot | | Sir Searchalot Joined: May 2005 Posts: 8,983 | The widest wheel/widest tire you could use, has not changed with the Camaro Diff install. The back space and wheel width that will work is calculated from the Wheel Mounting Surface (WMS) on the diff and on the wheel, using public school math and the tools MNSmith specified.
Right is right, even if everyone is against it, and wrong is wrong, even if everyone is for it. - William Penn | | | | | Joined: Dec 2014 Posts: 678 'Bolter | | 'Bolter Joined: Dec 2014 Posts: 678 | I have a Chevelle rear which is probably close to your Camaro. Without tubbing, 10-inch wide tire on an 8-inch wide wheel gave me an inch sidewall clearance on the inside and out. I used the standard offset that came on the wheel - don't remember what it was - 3-1/2 or 4 inches? MNSmith is right: there's no substitute for crawling under there with a tape measure and straight edge. This web site is invaluable for comparing various tire sizes: https://tiresize.com/
1951 Chevy Panel Truck
