1 members (Hotrod Lincoln),
104
Mod | | | Forums66 Topics128,089 Posts1,056,004 Members48,430 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Aug 2005 Posts: 99 Wrench Fetcher | | Wrench Fetcher Joined: Aug 2005 Posts: 99 | Done! Finally! Ground the splines down on the transmission Saturday with a Dremel and the clutch now fully disengages. Took it for a test drive and wow! Night and day from the original 3-speed even around town.
Thanks for everyone's help. | | | | | Joined: Sep 2003 Posts: 1,820 Shop Shark | | Shop Shark Joined: Sep 2003 Posts: 1,820 | Glad you got it going jthuma94! Isn't it great I got mine out last week end. As you said, even around town it is so much better. Wait until you shift into fifth gear.  It is like another world. Talk about cruising! Joe
"Truckin' Around .......... Since 1937!" My name is Joe and I am addicted to Classic Country Music. I just can't hep myself.Operators are standing by to take your calls! Now cruising in the Passing Lane | | | | | Joined: Oct 2005 Posts: 1,317 Shop Shark | | Shop Shark Joined: Oct 2005 Posts: 1,317 | Hey Josh.....good to hear it's operational!!!! The key to it all is in the splines. Your hard work has paid off! | | | | | Joined: Jan 2002 Posts: 244 Shop Shark | | Shop Shark Joined: Jan 2002 Posts: 244 | Yep, that extra gear makes a world of difference  | | | | | Joined: Jun 2004 Posts: 8,597 Riding in the Passing Lane | | Riding in the Passing Lane Joined: Jun 2004 Posts: 8,597 | I,m doing my 2nd one. I,m putting in a new engine at the same so I still have some wireing &vacuum tubes to do. I,t will be ready in a couple of days. They say money can't buy happiness. It can buy old Chevy trucks though. Same thing. 1972 Chevy c10 Cheyenne SuperIn the Gallery Forum | | | | | Joined: Mar 2003 Posts: 181 Shop Shark | | Shop Shark Joined: Mar 2003 Posts: 181 | When you guys swap in these T-5's, do you install a hydrolic clutch or keep the old mechanical linkage? | | | | | Joined: Dec 2005 Posts: 2,557 'Bolter | | 'Bolter Joined: Dec 2005 Posts: 2,557 | I kept my original linkage,throw-out bearing and pressure plate.I know some have used the hydraulic throw-out bearing.I can't tell you anything about the hydraulic conversion.I bet you could do a search on it and find some info. 1951 3100 Chevrolet1951 Chevrolet Suburban CarryallImage"A house is built with boards and beams. A home is built with love and dreams." "Look deep before you leap !!!" / "Everything is Everything" "If I say a mouse can pull a house, hitch him up"
| | | | | Joined: Aug 2005 Posts: 99 Wrench Fetcher | | Wrench Fetcher Joined: Aug 2005 Posts: 99 | The only thing that has to be changed is the clutch disc. Find one with a 14 spline 1" hub that has similar dimensions to the one you pull out of the truck. The original bell housing (on 1947 and later models), pressure plate, throw out bearing, and clutch linkage can be used. | | | | | Joined: Feb 2000 Posts: 364 Shop Shark | | Shop Shark Joined: Feb 2000 Posts: 364 | What did you do about fitting the shift lever? I've installed a T5 in my '42 1/2t with a stock seat and the shift lever needs some major bending to be able to operate properly. | | | | | Joined: Mar 2002 Posts: 553 Shop Shark | | Shop Shark Joined: Mar 2002 Posts: 553 | steveg - You answered your own question. That's exactly what I did to my shifter, I bent it. | | | | | Joined: May 2002 Posts: 144 Shop Shark | | Shop Shark Joined: May 2002 Posts: 144 | Steppenwood: Just looked at you pictures (I bent it) What a GREAT sequence.. documents the job really well. Thanks for putting the pictures up Ter | | | | | Joined: Nov 2005 Posts: 54 Wrench Fetcher | | Wrench Fetcher Joined: Nov 2005 Posts: 54 | steppenwood,
nice adapter plate for the T-5 conversion. Would your son be willing to sell one?
Dave | | | | | Joined: Jul 2006 Posts: 451 Shop Shark | | Shop Shark Joined: Jul 2006 Posts: 451 | I just finished my T-5 swap today with the drive shaft instal. My adapter was made by Buffalo Enterprises in Washington. IMHO the shifter in an old truck should reflect the measure of the man drivin it. This did not work as the throw on the box is long with the given heght, not to mention knocking the rear view out of alignment everytime I shifted into 4th or hit my passengers in the head trying for reverse. What I did do was cut and grind opposing notchs in both the T-5 and factory 3 speed shift levers, clamped them together, and welded them at the seams. This gives me a factory shifter with hegight just below the steering wheel. The throw is a bit long but I plan to remedy this with a Hurst or B&M shifter kit. Have a picure of two if interested. Cavebull | | |
