3 members (78buckshot, Phak1, NJC), 88 guests, and 2 robots.
Topics128,157
Posts1,056,876
Members48,458
#135615 10/09/2006 3:36 PM
Done! Finally! Ground the splines down on the transmission Saturday with a Dremel and the clutch now fully disengages. Took it for a test drive and wow! Night and day from the original 3-speed even around town.
Thanks for everyone's help.
#135616 10/09/2006 9:02 PM
Glad you got it going jthuma94! Isn't it great
I got mine out last week end. As you said, even around town it is so much better. Wait until you shift into fifth gear. grin It is like another world. Talk about cruising! eek
Joe smile
#135617 10/11/2006 2:42 AM
Hey Josh.....good to hear it's operational!!!! The key to it all is in the splines. Your hard work has paid off!
Webshot "Tips and tricks" and "Shoebox" Photo Albums
EXPERIENCE is the best teacher...but it gives the test first...and the lesson afterwards.
"What this generation tolerates...the next will embrace"
#135618 10/11/2006 10:03 PM
Yep, that extra gear makes a world of difference wink
#135619 10/11/2006 10:24 PM
Riding in the Passing Lane
I,m doing my 2nd one. I,m putting in a new engine at the same so I still have some wireing &vacuum tubes to do. I,t will be ready in a couple of days.
1972 Chevy c10 Cheyenne Super
#135620 10/12/2006 10:13 PM
When you guys swap in these T-5's, do you install a hydrolic clutch or keep the old mechanical linkage?
1965 Chevy C-10 Longbed Stepside
#135621 10/12/2006 10:38 PM
I kept my original linkage,throw-out bearing and pressure plate.I know some have used the hydraulic throw-out bearing.I can't tell you anything about the hydraulic conversion.I bet you could do a search on it and find some info.
1951 3100 Chevrolet
#135622 10/13/2006 3:55 PM
The only thing that has to be changed is the clutch disc. Find one with a 14 spline 1" hub that has similar dimensions to the one you pull out of the truck. The original bell housing (on 1947 and later models), pressure plate, throw out bearing, and clutch linkage can be used.
#135623 10/14/2006 1:14 AM
What did you do about fitting the shift lever? I've installed a T5 in my '42 1/2t with a stock seat and the shift lever needs some major bending to be able to operate properly.
Steve G.
1942 Chevrolet 1/2-Ton Pickup Truck
#135624 10/14/2006 2:42 AM
steveg - You answered your own question. That's exactly what I did to my shifter, I bent it.
#135625 10/15/2006 5:36 PM
Ter Offline
Steppenwood:
Just looked at you pictures (I bent it)
What a GREAT sequence.. documents the job really well.
Thanks for putting the pictures up
Ter
#135626 10/15/2006 7:01 PM
DW Offline
steppenwood,
nice adapter plate for the T-5 conversion. Would your son be willing to sell one?
Dave
#135627 10/28/2006 6:15 AM
I just finished my T-5 swap today with the drive shaft instal.
My adapter was made by Buffalo Enterprises in Washington.
IMHO the shifter in an old truck should reflect the measure of the man drivin it. This did not work as the throw on the box is long with the given heght, not to mention knocking the rear view out of alignment everytime I shifted into 4th or hit my passengers in the head trying for reverse.
What I did do was cut and grind opposing notchs in both the T-5 and factory 3 speed shift levers, clamped them together, and welded them at the seams. This gives me a factory shifter with hegight just below the steering wheel. The throw is a bit long but I plan to remedy this with a Hurst or B&M shifter kit.
Have a picure of two if interested.
Cavebull
cavebull
Stovebolts - so easy even a Cavebull can do it.
https://www.flickr.com/photos/dodsonbrett/collections
