1 members (78buckshot), 106 guests, and 2 robots.
Topics128,285
Posts1,058,278
Members48,483
My truck has had some weird mods done to it before my wife bought it for me, like aftermarket gauges and whatnot.
I figure that this one is not original but I have been wrong before, what do you think?
62' GMC Fleetside 3/4 ton 235 4-speed.
Time makes fools of us all.
Add on by PO.
Sir Searchalot
Sir Searchalot
Yours is a GMC, but in 1962 the Chevy C10 came with factory turn signals as standard equipment. So yours did too. You will probably see a hole in the column for the original lever if you take that aftermarket switch off. The PO did not want, or didn't know how, to repair the original switch.
Thank you guys, that makes a lot of sense. My blinkers never worked, and I was pretty sure that wasn't original but if it was worth saving I would get it working again but I think I will try to track down an original lever and get it blinking again.
Moderated by  ndkid275, Phak1
