| | | Forums66 Topics128,014 Posts1,055,327 Members48,419 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Nov 2000 Posts: 1,966 'Bolter | | 'Bolter Joined: Nov 2000 Posts: 1,966 | Can a person use solid lifters with a cam made for hydraulic lifters?
Professional Novice
| | | | | Joined: Apr 2005 Posts: 7,440 Bolter | | Bolter Joined: Apr 2005 Posts: 7,440 |
| | | | | Joined: Feb 2004 Posts: 29,746 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,746 | The shape of the cam lobe is all wrong. You would have to use a valve clearance specification of around .005", and adjust the valves frequently to avoid noisy operation and/or valves that fail to seat properly and cause compression leakage and valve burning. Not many people would be willing to do the maintenance required to keep an engine running right. Jerry
Professional Novice
