2 members (Hotrod Lincoln, Hush), 58 guests, and 4 robots.
Topics128,021
Posts1,055,355
Members48,420
#1355707 04/17/2020 2:57 PM
Can a person use solid lifters with a cam made for hydraulic lifters?
Professional Novice
No!
H Online: Content
The shape of the cam lobe is all wrong. You would have to use a valve clearance specification of around .005", and adjust the valves frequently to avoid noisy operation and/or valves that fail to seat properly and cause compression leakage and valve burning. Not many people would be willing to do the maintenance required to keep an engine running right.
Frank50 #1356205 04/20/2020 11:29 AM
Thank you.
Professional Novice
