4 members (moparguy, Phak1, NJC, Peggy M), 77 guests, and 1 robot.
Topics128,157
Posts1,056,876
Members48,458
Been working on replacing floor pans , rockers and cowls . Theses aftermarket panels sure need a lot of desire to get in place.
1953 Chevy 1/2 ton panel truck
1957 Chevy 3200 truck
Sir Searchalot
Sir Searchalot
Nice job.....and cleco clamps! Proooooooooofessional
Thanks bartamos
You got that right! Wait till you get to the inner cowl panels. big_eek
Looking good. thumbs_up
Yes the inner cowl panel is a joke, got both inners in but a lot of cutting to get them to fit . Thanks klhansen
Fond memories of doing ALL the inner/ outers, floors, supports, Everything on my 51 panel.....
Great job.
Thanks Squire
Did your front cab mounts line up? Mine didn't and I had to move them in the floor pan. I used an older style of patch panel, 18 years ago.
1951 1 Ton Completed
My 1st panel truck's firewall sagged so bad that the clutch and brake pedals scrapped when pushing them in.
I had to attach a engine hoist to the firewall and raised it up so the pedals had enough clearance.
My hinge pillars at the floor and the front mounts were rusted bad.
The roof and the windshield side pillars were the only thing that was holding the firewall.
The Toe board was basically laying on the frame rails.
The doors were rubbing when I would try to close them.
I raised the firewall and checked the door line at the striker, when it looked good I started to weld.
xfiles
I had the same issues as jorb with the front cab supports basically collapsed and the pedals scraping the top of their openings. The steering column was doing most of the support of the front of the cab.
I pulled the cab off and braced it, paying attention to the door positions, and double checked them before I welded the rockers in. They SHOULD fit when I put them back on.
I also confirmed the position of the front cab mount bolt holes with respect to the firewall using the dimensions in the FAM.
It looks to me like the OP has done a good job of bracing the door openings.
truckernix,yes I had the same problems. The passenger side was off a little and the drivers side a lot ,had to jack up the front of cab was sitting on the frame. Floors ,cowls and supports all in bad shape, have most of it done now on the floors and cowls still have dash and upper cowl to replace , after cleaning it all up been finding a lot more panels to replace. The seat riser is repairable but the floor under is rusted out. Mine is like jorb and klhansen will have to start learning on how to make panels for the rear when I get there. Cool panel truck but a ton more work than my 57 Chevy truck was glad that’s finished.
Klhansen I hope I put enough supports in pain to work around but so far all is staying in place.
Your supports look good to me. I agree that they're a pain to work around. My support between the A pillars is bolted in place with the door hinge bolts, and it was a good thing as I needed to loosen it and pull the A pillars together a bit when putting the floor in. They were maybe 1/8 inch too wide.
Finished front floors and inner cowl was able to bolt cab back down to frame, all looking good ,have outer cowl on right side to do . Waiting for my dash to come in and install, hopefully can start on floor under seat riser was able to save it but floor underneath is rusted out .
Ohhh, that looks so familiar. Looks like your "doing it right" so you can "ride with pride" when you git r done. Hang in there. YOu were 2/3 done when you start a job!!.....thats what my dad always told me.
Wow, like your dad’s saying makes me feel I got something accomplished instead of starring at all the work to go. Thanks Achipmunk
Made a new floor pan under my seat riser, first time I have ever made a floor pan now I have to repair my seat riser and mount it .
Nice!
Did you roll beads into it and all?
Yes , started with a flat sheet of steel took my brother and myself to bead roll and used bead roller to bend the flanges ,to long to do by myself. Now that I tried it I think I can make my floor pans to get to fit better than some of the repops had to cut and fit the front floor pans but this one only had to measure and bead the lines and bend the flanges.
Wow you do nice work. On my cab the seat riser is a stiffener that helps support the floor pan.
Thank you truckernix , also put under the floor pan a c-channel under the seam where the two floors meet found a heavy gauge channel only 1/2 height by 1 1/2 wide
Finished up the floor except for seat riser , started d on setting up dash
Looking good! thumbs_up
Thanks klhansen
