0 members (),
136
Mod | | | Forums66 Topics128,193 Posts1,057,259 Members48,466 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Feb 2010 Posts: 3 New Guy | | New Guy Joined: Feb 2010 Posts: 3 | Has anyone used a chevy 265 for a swap. I need to keep the riginal transmission. Will it bolt up? thanks! | | | | | Joined: Aug 2016 Posts: 14 Wrench Fetcher | | Wrench Fetcher Joined: Aug 2016 Posts: 14 | The sm420 will work if you use the correct bell housing with the 265, big issue is if it's a early 265 that didn't have the 3 bolt mounts on the sides of block. Goes with out saying ur going to fab or use a kit mount that bolts to front of block | | | | | Joined: Jul 2014 Posts: 892 'Bolter | | 'Bolter Joined: Jul 2014 Posts: 892 | Are you swapping for a 265 because you have one or for more power? If so, consider that a 261 is only four cubic inches less and at usable truck RPM (say 2500) has just about as much torque. And it's a way easier swap. 1951 3800 1-ton"Earning its keep from the get-go"In the DITY Gallery1962 261 (w/cam, Fenton headers, 2 carbs, MSD ign.), SM420 & Brown-Lipe 6231A 3spd aux. trans, stock axles & brakes. Owned since 1971. | | | | | Joined: May 2017 Posts: 330 'Bolter | | 'Bolter Joined: May 2017 Posts: 330 | If the 265 fits, why not go with a 350 or 400? Looks identical, side mounts can be ground off if you want them gone, more(!) power, easier parts.
Mac :{)
1962 K10 short step side, much modified for rally 1969 T50 fire truck, almost nos, needs a few things
| | | | | Joined: Jul 2004 Posts: 2,994 'Bolter | | 'Bolter Joined: Jul 2004 Posts: 2,994 | Remember that putting V-8's in these trucks usually results in some clearance problems with the steering box. When they put the 307 in mine they shifted the steering box slightly to the left. It works ok for what it's used for, but the tire does rub against it on a hard left turn. | | |
