5 members (Tinker5, mick53, Bill Hanlon, klhansen, J Lucas), 116 guests, and 3 robots.
Topics128,193
Posts1,057,255
Members48,466
Has anyone used a chevy 265 for a swap. I need to keep the riginal transmission. Will it bolt up? thanks!
The sm420 will work if you use the correct bell housing with the 265, big issue is if it's a early 265 that didn't have the 3 bolt mounts on the sides of block. Goes with out saying ur going to fab or use a kit mount that bolts to front of block
1 Offline
Are you swapping for a 265 because you have one or for more power? If so, consider that a 261 is only four cubic inches less and at usable truck RPM (say 2500) has just about as much torque. And it's a way easier swap.
1951 3800 1-ton
In the DITY Gallery
If the 265 fits, why not go with a 350 or 400? Looks identical, side mounts can be ground off if you want them gone, more(!) power, easier parts.
Mac :{)
1962 K10 short step side, much modified for rally
1969 T50 fire truck, almost nos, needs a few things
R Online: Content
Remember that putting V-8's in these trucks usually results in some clearance problems with the steering box. When they put the 307 in mine they shifted the steering box slightly to the left. It works ok for what it's used for, but the tire does rub against it on a hard left turn.
Rich
1947 Loadmaster
1947 Chev. Loadmaster
1959 Chev. Viking 40
