6 members (68ironhead, Ridgeback, Phak1, Joe H, Tinker5, GMCJammer51), 74 guests, and 0 robots.
Topics128,196
Posts1,057,398
Members48,471
#1352319 03/30/2020 1:00 AM
Hello. Doing some work on my 47 3100 with the original 216 engine and noticed one of the freeze plugs is leaking. It's just below the water pump and looks to be about 2 inches. Can someone tell me the exact size and where I can get one without having to by a set? Thanks.
1947 3100
47chevySC #1352332 03/30/2020 2:06 AM
You can buy as many or as few as you want at any auto parts store. As for size someone will be along shortly.🛠
47chevySC #1353134 04/03/2020 6:22 PM
Hello guys. Can someone help me out on this please? I took the plug out today. I never saw one like it. It's flat like a 2 inch washer with no hole in it probably 1\8 inch thick. Went to the local Napa but they did not have one and could not get one. Can someone give me a source to order one?
1947 3100
47chevySC #1353139 04/03/2020 6:50 PM
Not sure about now but back when I delivered commercial parts for Advance Auto they had a "bin" with freeze plugs of different sizes and some different shapes. Give them a try......if no luck, look for the oldest longest running parts store in your area. You may have to try one somewhere around Laurens, Easely or even Spartanburg.....like the old Spartan Automotive place which is now a carquest but they use to do machine work/rebuilds.
47chevySC #1353140 04/03/2020 6:55 PM
[img]https://www.stovebolt.com/ubbthreads/ubbthreads.php/ubb/download/Number/16669/filename/16668.jpg[/img] is one of these what you need. Left has no lip. Right one does. Both are 2 inch wide
1949 gmc 1-ton
47chevySC #1353141 04/03/2020 6:57 PM
Both are by dorman products. Numbers are on them. John
1949 gmc 1-ton
47chevySC #1353142 04/03/2020 7:00 PM
1949 gmc 1-ton
47chevySC #1353143 04/03/2020 7:07 PM
1949 gmc 1-ton
47chevySC #1353162 04/03/2020 8:38 PM
Sir Searchalot
Sir Searchalot
Wow! we have found the original "Johnny on the spot" Awesome.
I have a favor to ask so that I don't go crazy. I am retired and come from the mechanical design world. Please don't refer to something round as being 2" wide. It is 2" in diameter. smile
47chevySC #1353163 04/03/2020 8:42 PM
Jeez. Get a life. Lol
1949 gmc 1-ton
bartamos #1353164 04/03/2020 8:44 PM
At least he didn't specify the thickness as xx "guage". LOL
47chevySC #1353165 04/03/2020 8:44 PM
Sir Searchalot
Sir Searchalot
It's just that this could slightly tilt the world and cause global freezing. Plus I'm always on the edge and this puts me over.
47chevySC #1353166 04/03/2020 8:46 PM
I'll try my goodest
1949 gmc 1-ton
47chevySC #1353167 04/03/2020 8:48 PM
Sir Searchalot
Sir Searchalot
Farfegnugen
47chevySC #1353190 04/03/2020 11:24 PM
Crusing in the Passing Lane
2" wide is misleading, I agree with Bartamos.
Ed
47chevySC #1353193 04/03/2020 11:34 PM
You know what. I gave him several pictures of the plugs. If he cant figure it out. Not my problem
1949 gmc 1-ton
47chevySC #1353198 04/04/2020 12:10 AM
Sir Searchalot
Sir Searchalot
Johnny, we are joking.
47chevySC #1353199 04/04/2020 12:18 AM
Yup. I know. You're pulling my chain. 👍
1949 gmc 1-ton
47chevySC #1353200 04/04/2020 12:20 AM
My wife works for a school. Been locked up here for 3 weeks with her. You see where this is headed?
1949 gmc 1-ton
47chevySC #1353205 04/04/2020 12:29 AM
Appropriate but probably not allowed here, but funny nonetheless.
47chevySC #1353206 04/04/2020 12:30 AM
Think I'll start knitting!!
1949 gmc 1-ton
47chevySC #1353211 04/04/2020 12:48 AM
Sir Searchalot
Sir Searchalot
Make it the right Diameter.
47chevySC #1353212 04/04/2020 12:49 AM
This thread has been officially hijacked! Back on track please.
47chevySC #1353213 04/04/2020 12:49 AM
Hi Johnny. Thanks for the info. Yes it does look like the one on the left. So where can I order one?
1947 3100
47chevySC #1353215 04/04/2020 12:59 AM
Sir Searchalot
Sir Searchalot
This is $5.50 for 10 or $5.79 for 1.
Unless a cup type would hit something inside the hole or black flow, a cup type would be better/easier to install. you can get a brass 2" diameter cup type which will never rust.
47chevySC #1353216 04/04/2020 12:59 AM
Every auto parts store in the world carries freeze plugs. I find it hard to believe you got turned away by NAPA. It’s not even an odd size. You can use either one as long as it is the right circumference but as bartamos said the one on the right is easier for a novice to install.
Sir Searchalot
Sir Searchalot
circumference? I'm not taking the bait.
47chevySC #1353219 04/04/2020 1:02 AM
I tried🤣
47chevySC #1353222 04/04/2020 1:17 AM
Sir Searchalot
Sir Searchalot
Make sure of the diameter. The disc type are installed with the "dome"/convex facing out. You hammer on it and it expands like a giant welch plug (carbs). The cup type is just pressed/tapped in. if the hole has a ridge/a stop inside, I believe that means you have to use the disc.
47chevySC #1353243 04/04/2020 3:32 AM
I believe I used a #2 permatex sealant on mine years ago. Had a machinist recommend I use it on the expansion plugs,it stays soft and doesn't harden up .
1951 3100 Chevrolet
47chevySC #1353244 04/04/2020 3:42 AM
My wife ran out of things to clean yesterday. Today I believe she cleaned the soap in the soap dish in the Man bathroom, which is 49 square feet (Thought I'd send bartamos over the cliff with another dimensional measurement.)
(Sorry mod, I could not stop myself. Theses are indeed trying times.)
47chevySC #1353258 04/04/2020 6:56 AM
Sir Searchalot
Sir Searchalot
How many meters is it out to the "man bathroom"?
47chevySC #1353310 04/04/2020 5:14 PM
And then there's the freeze plug 600 W heater that has an expandable O-ring for a snug fit. (Or should that be "which has an expandable......"?)
I doubt you'd need a heater in SC like we might in MT but it does plug up the hole nicely.
Just got 10 of them ordered. Never had seen one like that before. Could not find one on ebay that looked like that for the 216. Spent the day cleaning the motor trying to get it ready for paint. Thanks again for your help and sure I will have more questions the further I go.
1947 3100
47chevySC #1354834 04/12/2020 8:14 PM
47chevySC...it's a given you will have more questions and this is the place to get them answered. Just remember, everyone has an opinion...make it safe and build it like you want.
