1 members (Hotrod Lincoln),
72
0
Mod | | | Forums66 Topics128,049 Posts1,055,680 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Mar 2010 Posts: 10,272 Renaissance Man | | Renaissance Man Joined: Mar 2010 Posts: 10,272 | Can anyone tell me what the difference is between a steering box/mast from a '54 vs the earlier ADs? Can a '52 box/mast be used in a '54?
| | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | "Can anyone tell me what the difference is between a steering box/mast from a '54 vs the earlier ADs?" The 1954 steering mast has holes in it for the RPO/Accessory turn-signal wire-harness. And, there is a different "cover/cone" around the steering column, under the steering wheel.
"Can a '52 box/mast be used in a '54?" I do not know, but, I would bet "yes"; but (again), wait to hear from others. | | | | | Joined: Jan 2001 Posts: 5,337 'Bolter | | 'Bolter Joined: Jan 2001 Posts: 5,337 | 1954 was the first year for built in turn signals, so the column has a cutout for the wires to run down the inside of the column.
See the USA in your vintage Chevrolet! My Blog | | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | Dave,
Except for those differences in the 1954 steering column, could someone use an earlier 1/2-ton column in a 1954/55st truck?
Would it bolt-right-in/on - you would use the earlier steering wheel/collar? | | | | | Joined: Jan 2001 Posts: 5,337 'Bolter | | 'Bolter Joined: Jan 2001 Posts: 5,337 | I can not think of a reason the earlier box would not fit. Same splines for pitman and steering wheel, and same mounting. The parts book shows the 1947-53 steering shaft to be 5/16" longer on the 1954.
