0 members (), 129 guests, and 1 robot.
Topics128,115
Posts1,056,292
Members48,439
#1351361 03/24/2020 12:22 AM
I've got to remove the wiper arms on my 47 to reposition them. Is there a trick to moving the little catch finger thingie that holds the arm on?
Ex Hall Monitor
Ex Hall Monitor
Tiny--That is not an ID.....................
That's a better design. Mine has a little finger on the bottom of the wiper arm that slips under the the spline area of part on the truck. I've got a couple extra water arms. I'll take a pic when I get to work tomorrow morning.
This little finger that holds the wiper on.
Trico actually made a set of tools just for this job. After you do it once you will see how easy it really is.
https://www.flickr.com/photos/advance-design_parts_co/8129475347/in/album-72157631868452754/
Lisle tool number 65750 made in USA too.
Wiper arm removal tool 1947-98 truck. And 67-69 Camaro.
Todd
1950 Chevy 3100
1951 Chevy Panel Truck
I've removed them with a small flat blade screwdriver, either straight or bent at the end, inserted behind the little clip. Pointed end of a can opener has done it as well. Keep in mind that if you tweak that little spring clip a lot, it has been known to fall out of the wiper arm when you pull the arm off of the post. If this happens, you can easily tweak (bend) the clip and then insert it into the arm.
Craig
Cool thanks.
