7 members (Shade Baby, Pete1946, frogfarmer, baldeagle, 1955 1 Series, Jon G, 1 invisible),
97
8
Mod | | | Forums66 Topics128,106 Posts1,056,213 Members48,436 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jun 2006 Posts: 74 Wrench Fetcher | | Wrench Fetcher Joined: Jun 2006 Posts: 74 | I'm working my way through all the post regarding IFS for my 56 TF. I would really like to minimize the drop to a couple of inches. I've looked at Fatman, TCI, Heidt and Jimmy Meyers IFS products and all seem great. It's a little confusing trying to land on one vendor.
What criteria did you folks use to evaluate one from another? I've heard from a Hot Rod shop localling that Heidt IFS are tough to align. Yet they seem to be a poplar IFS choice.
Enlighten me!! | | | | | Joined: Jun 2004 Posts: 8,597 Riding in the Passing Lane | | Riding in the Passing Lane Joined: Jun 2004 Posts: 8,597 | That,s the reason i,ve never changed to IFS. I like the stock height or maybe just a slight lowering. All i,ve seen are way down on the ground. The one I would look into is the crossmember from a 71-72 pickup. You have to narrow it but the few i,ve seen are real good. They say money can't buy happiness. It can buy old Chevy trucks though. Same thing. 1972 Chevy c10 Cheyenne SuperIn the Gallery Forum | | | | | Joined: May 2006 Posts: 8,351 'Bolter | | 'Bolter Joined: May 2006 Posts: 8,351 | I can't agree on the Heidt's being hard to align. I've done a plenty of Mustang 2 and Pinto alignments, the stock control arms are a pain in the arse to get right. The Heidt's design eliminates the original slip shaft setup for a turnbuckle type. It looks much easier to get set right and more likely to stay right ot me. I will agree with Wrenchbender, I like the stock hight too. I don't know if the kit is availible anymore, but there used to be a kit that used the late '70s to mid '80s Chrysler rear drive front end. It was a tortion bar type, the bars run across the front instead of paralell with the frame. It would allow you to put the hight where you want by adjusting the bars. The only 2 drawbacks were the sloppy Crysler steering box and the brake on them were not too good either. But I would think that could be overcome with the parts that are availible now.
Bill Burmeister | | | | | Joined: Jul 2006 Posts: 26 Apprentice | | Apprentice Joined: Jul 2006 Posts: 26 | I spent over a year looking at different IFS systems. I decided to go with Progressive Automotives IFS. The reason I chose them is because they are a local company to me here in Ohio. Also they make everything after you order it and it is custom to your application. I also like the fact that I can get the boxing plates, x-members, IFS system, motor mounts, brake booster setup, and several different rearend setups all at one shop. Give Bob at Progressive a call and ask him about the ride height you want and see what he says. | | | | | Joined: Jul 2006 Posts: 23 Junior Member | | Junior Member Joined: Jul 2006 Posts: 23 | The late Volare front ends are good, not to hard to install. The brakes are disc and large enough for most uses. The torsion bars are easy to adjust plus the front ends are cheap. Also AMC Pacers have a nice front suspension with rack and pinion steering. Also very easy to install. do a search someone on this site has a kit. | | | | | Joined: Jun 2006 Posts: 74 Wrench Fetcher | | Wrench Fetcher Joined: Jun 2006 Posts: 74 | Thanks for the responses. I just got off the phone with Fatman and their drop is at least 4 inches. I like their approach, but I'm really struggling with the drop.
I'll look at Progressive again and do some more homework on Volare and Pacers. First I have to get over the idea of having Pacer cadaver parts on my 56... :p | | | | | Joined: Jun 2006 Posts: 74 Wrench Fetcher | | Wrench Fetcher Joined: Jun 2006 Posts: 74 | I just got off the phone with Jimmy Meyers Racing and their IFS is adjustable. The most conservative adjustment would drop the truck 2". If needed, I suppose one could change out he coils as well to keep it at or near stock height. I like the technology, but the pricing needs some getting use to. I'm gonna have to sell my CFO on this purchase! | | | | | Joined: Jun 2005 Posts: 1,756 Shop Shark | | Shop Shark Joined: Jun 2005 Posts: 1,756 | All those kits are a bunch of $ just get a donor truck and start welding. Modify that as you go along to obtain the drop you want. stock to a frame dragger. Lots of people here will give you advice on how to go about it. | | | | | Joined: Apr 2005 Posts: 2,832 'Bolter | | 'Bolter Joined: Apr 2005 Posts: 2,832 | It's been my experience that one needs the van front crossmember to fit the 55-59, the pickup is two narrow to fit up on the frame rails. The pickup does fit the 47-54 with 9/16" spacer on each side. 1/2" can be used but will suck the rails in a tad. The Pacer, which is BY FAR the easiest to install, has the exact same track width, a cheap kit is available from Chassis Engineering, and you get to keep ALL of your original frame so there's no fabbing core support, bumper mounts, etc. You can choose the heigth you want by how high or low you mount the pickup frame in Pacer crossmember. Too bad they're extinct. They no longer have rebuilt power racks, rotors, or ball joints for them. They will rebuild your rack, the brakes are of the ford design, and you can mig the pacer upper balljoint holes shut and redrill for monte carlo since the stud is the same taper and length. A threaded sleeve can be welded to the bottom A-frame and a chrysler ball joint used. I locate mine through shear bribery; I offer the fork lift operaters, not the owners, of crusher companies a $100 reward for calling me when they find a pacer. You then have to buy them from the salvage yard owner. They mostly unbolt so not hard to pull especially when the happy forklift guy holds them up in the air.
Evan
| | | | | Joined: Jul 2005 Posts: 161 'Bolter | | 'Bolter Joined: Jul 2005 Posts: 161 | I also like the pacer IFS. I put it in my truck. I got mine by contacting a guy on ebay who was selling parts and asked him to ship the whole front end from canada. It was still super cheap. I got the rest of the parts needed to rebuild it all from ebay or autozone, etc. so it was still pretty inexpensive. I would guess that I have about $800 to $900 in the front end and it just bolts in and can unbolt right out. It also LOOKS like it was made for the truck... a real IFS not a tubular looking thing that is out of place on an old truck.
1946 Chevy Pickip
| | | | | Joined: May 2005 Posts: 323 Shop Shark | | Shop Shark Joined: May 2005 Posts: 323 | Check out my 55 second series project. I too did not want a slammed truck so I had a local hot rod builder notch my custom IFS 2" into the frame. I think you could put it wherever you want to achieve your desired height. Matt Droege http://www.stovebolt.com/gallery/droege_matt_1955_03.htm | | | | | Joined: Jun 2006 Posts: 74 Wrench Fetcher | | Wrench Fetcher Joined: Jun 2006 Posts: 74 | Matt,
Thanks for the information. I've had a call into Messler's for a week now with nary a response. I'm also looking at a local guy here in Colorado who builds an IFS that is similar to Heidt's. I've got to validate what he can do and land on a decision for my IFS. I'm getting closer. | | | | | Joined: Jun 2006 Posts: 382 'Bolter | | 'Bolter Joined: Jun 2006 Posts: 382 | I'm buying a '51 3600 and have been wondering about whether Pacer's or Volare's fit. I've read that some if not all MII kits wont work on the 3600 frame. Is this true? | | | | | Joined: Jun 2006 Posts: 74 Wrench Fetcher | | Wrench Fetcher Joined: Jun 2006 Posts: 74 | Under the hearding "For What It's Worth". I just got off the phone with Industrial Chassis in Phoenix. They made a Dakota IFS that was heavier and well suited for rodders wanting realatively stock height IFS for TF trucks.
They stopped production and refocused their crew on turn-key solutions / builds. They are working to find a "well known" suiter to take over that IFS line and make improvements. He said give it 6 months and stay tuned as the potential buyer would layout an advertizing blitz around this particular IFS line. | | | | | Joined: May 2005 Posts: 323 Shop Shark | | Shop Shark Joined: May 2005 Posts: 323 | Jim Messler is in the hospital for bypass surgery so that's why you haven't heard from him. He really runs the place by himself. | | | | | Joined: Apr 2004 Posts: 11 New Guy | | New Guy Joined: Apr 2004 Posts: 11 | Hi fellas , I haven't logged in for quite awhile because I've been too busy to work on mine . I aquired a pacer ifs and want to install soon on my TF '58 GMC . question is are the frame widths the same on AD trucks compared to TF ones? from my measurements my TF seems wider which means I'd have to notch the outer frame rails to fit btwn the shock towers . Then weld the towers to the notched area and box the inner rail . Does that sound right ? :confused: If everything's coming your way , your in the wrong lane... 1958 GMC Shorty | | | | | Joined: Apr 2005 Posts: 2,832 'Bolter | | 'Bolter Joined: Apr 2005 Posts: 2,832 | The TF is wider than the AD so a pacer might be dicier to use. Chassis Engineering makes the kit for the AD so you might give them a call to check on the TF. If you can't use the pacer you will have NO trouble selling it.
Evan
| | | | | Joined: Feb 2006 Posts: 117 Wrench Fetcher | | Wrench Fetcher Joined: Feb 2006 Posts: 117 | Since I'm in the same boat with IFS Q's...Will ANY year of Pacer work, or only certain years? Thanks-Dano
my truck gets better every day...every PAYDAY | | |
