3 members (Guitplayer, Patina 54, Steelonsteel), 42 guests, and 2 robots.
Topics128,035
Posts1,055,441
Members48,422
#135055 08/15/2006 4:09 PM
I pulled all the sheet metal from my 55.5 1/2 ton then noticed the frame is bent in the front just before were the firewall was. I would like to get a straight frame with IFS. I heard that a 2wd 73-87 1/2 ton short box chevy will work. Or a s-10 2wd extended cab frame would work. Does anyone have any information on this. If so how much fabing would be needed to pull this off. What are the pros and cons.
thanks
red55
#135056 08/15/2006 6:36 PM
I too would like to know if the 73-87 2wd is a quick swap. I have a 65 c10 2-wd non-power steering and brakes.
I just bought a 85 c10 with p/s and brakes.
I've been told that ya can remove all the frame rail bolts and riverts and slide the whole mess up under the 65.
True???
Thanks, George Hood . CLinton N.C.
1965 C-10 fleetside shortbed BLACK
82 c-10 longbed 6 cyl.
58 Lincoln 2-dr coupe Black w/white & blk.
59 lincoln 4-dr. parts car
#135057 08/15/2006 6:49 PM
V
V Offline
Kind of the same thing here..I have 54 3/4 but would like to put cab on S10 or something. Maybe make my own flatbed...Virg
#135058 08/19/2006 6:19 PM
I'm sure someone out there has to know.
#135059 08/26/2006 1:35 AM
how come no help heare ?
#135060 08/26/2006 2:31 AM
actually, the hi-po shop area doesn't seem to get a whole lotta traffic,,do a search for "frame" here. the 73-87 crossmember will swap easily into the 65, but I think the s10 frame is better choice for the 54 & 55,,brian
My \'64\'s in the Gallery
Pictures in my Photobucket
1964 C10 Custom Cab 350/700R4
1964 Suburban 350/700R4
1979 Ford F350 4x4 400/c6
#135061 08/28/2006 3:46 PM
A mid 80's S-10 longbed regular cab will do the trick.
Here's a fella that sells a kit to do the conversion. If your good at fabricating, you could probably tackle it yourself without the kit.
http://www.ad-engineering.com/
-Rich
#135062 08/28/2006 6:55 PM
Junior Member
Junior Member
I am looking to put the sheet metal from my 1939 chevy on a more modern 70s - 80s frame and drivetrain any one have any info smile
