5 members (1955 1 Series, 49nut, rfs56trk, Eisenholtz, tclederman), 88 guests, and 0 robots.
Topics128,046
Posts1,055,618
#1346824 02/17/2020 6:46 AM
I have a 1946 fully restored but it's not that much fun to drive. I bought a 1951 3600 long bed 5 window to restore. You could say it's in kit from at the moment. I started looking at 2008 - 2012 Chevy canyons. The wheel base is within an 1 inch of the 51. Has any one put the body of a 49- 53 on a Chevy canyon or th c colarado?
GWWirth #1346925 02/18/2020 12:52 AM
There's a ton of threads on S10 swaps, but I've never seen one on a Canyon/Colorado. I think it's because the S10's are cheap and plentiful. Not to mention there is a huge aftermarket following. Looking at the frame of a Colorado, they look like a much better design than the S10. The S10 curves and narrows and has a lot going on. The Colorado seems a little simpler, I would think it would yield itself to a chassis swap very well.
1954 3600 Chevy Truck
"The Fake Truck"
More pix on Photobucket
Whitedog #1346980 02/18/2020 7:15 AM
That is my thought as well. More research to do.
GWWirth #1349069 03/06/2020 8:52 PM
Maybe you will be our up and coming expert on that . Maybe time for something different. It sounds like a good idea . I thought about it when I started my project but couldn't find one affordable . a coworker had an S10 4X4 with a bad engine $400 later I am hoping to keep 4 wheel drive, and stock look. I am blessed with the three welders mig,tig, arc and a lot of scrap metal . who knows what will roll out of the barn someday. I have not found anyone out there that has done this yet. Good luck .
GWWirth #1349146 03/07/2020 3:58 PM
Another one to look at is in the blue oval arena. The 1st gen Sport Trac is 125.9 wheel base, which is about perfect for a 3600 truck. I believe the Ranger ext. Cab is the same. The second gen Sport Trac is 130" wheel base. A little long, but some frame shortening would be required. The bonus with it is the IRS rear suspension. You could commit bow-tie heresy and put a blue small block between the frame rails also.
"The Fake Truck"
