2 members (baldeagle, Shardean),
31
Mod | | | Forums66 Topics128,037 Posts1,055,466 Members48,422 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Aug 2010 Posts: 775 'Bolter | | 'Bolter Joined: Aug 2010 Posts: 775 | I have a 1946 fully restored but it's not that much fun to drive. I bought a 1951 3600 long bed 5 window to restore. You could say it's in kit from at the moment. I started looking at 2008 - 2012 Chevy canyons. The wheel base is within an 1 inch of the 51. Has any one put the body of a 49- 53 on a Chevy canyon or th c colarado? | | | | | Joined: Mar 2008 Posts: 1,775 'Bolter | | 'Bolter Joined: Mar 2008 Posts: 1,775 | There's a ton of threads on S10 swaps, but I've never seen one on a Canyon/Colorado. I think it's because the S10's are cheap and plentiful. Not to mention there is a huge aftermarket following. Looking at the frame of a Colorado, they look like a much better design than the S10. The S10 curves and narrows and has a lot going on. The Colorado seems a little simpler, I would think it would yield itself to a chassis swap very well. | | | | | Joined: Aug 2010 Posts: 775 'Bolter | | 'Bolter Joined: Aug 2010 Posts: 775 | That is my thought as well. More research to do. | | | | | Joined: Mar 2017 Posts: 25 'Bolter | | 'Bolter Joined: Mar 2017 Posts: 25 | Maybe you will be our up and coming expert on that . Maybe time for something different. It sounds like a good idea . I thought about it when I started my project but couldn't find one affordable . a coworker had an S10 4X4 with a bad engine $400 later I am hoping to keep 4 wheel drive, and stock look. I am blessed with the three welders mig,tig, arc and a lot of scrap metal . who knows what will roll out of the barn someday. I have not found anyone out there that has done this yet. Good luck . | | | | | Joined: Mar 2008 Posts: 1,775 'Bolter | | 'Bolter Joined: Mar 2008 Posts: 1,775 | Another one to look at is in the blue oval arena. The 1st gen Sport Trac is 125.9 wheel base, which is about perfect for a 3600 truck. I believe the Ranger ext. Cab is the same. The second gen Sport Trac is 130" wheel base. A little long, but some frame shortening would be required. The bonus with it is the IRS rear suspension. You could commit bow-tie heresy and put a blue small block between the frame rails also.
