10 members (Shaffer's1950, Cletus1950, Leo, NAPCOStormTrpr, Otto Skorzeny, GDW, MNSmith, Hanks custodian, Peggy M, Hotrod Lincoln), 103 guests, and 1 robot.
Topics128,139
Posts1,056,455
Members48,441
#134879 07/28/2006 7:16 PM
After looking at the T-5 set up and having to go through finding a used V-8 unit then a tail shaft and still having a trans that is weak.
I gave Jeff ( owner) of Classic Chevy a call. WAY more helpful than Keisler Auto. ( see note at end) He went though all items I would need and after talking with him it was VERY clear that he was intested in making sure that I was getting the correct product. Price wise 2595 for the TKO 600 that is geared for my 3.73 rear gear.
I guess I have a hard time wanting to buy a used T-5 trans that may or may not need a re build plus all the hassel of finding one and then the other parts needed. Having the speedo work and be correct another issue solved with the new trans. Best price I could find in 4 states around me was 700 for a used trans, plus the tail shaft at 250, plus a re build kit for the trans I was into the trans too much and knowing that it would still break if I abused it. So the choice was made to use the TKO unit.
I will be happy to let you guys know how it goes and how easy ( or not) it is to install and how it works once done.
Side note " Keisler" gave them a call first and it was very clear that they are more intstrested in getting your credit card number and that was it. Very rude not willing to answer hardly any questions on the trans. Basicly read the instructions, figure it out for your self. Which really is all fine and good as we fab bikes every day so building a cross member or what ever needs to be done will not be a issue but still NO way would I spend one dime with them. As a owner of a shop (myslef) they really could use some lesson's in customer service.
As for C/C I give them a thumbs up. ( and they are a little bit more money not that it matters)
Customer service is what we do best here and what C/C is offering.
As for the call I just phoned,... had no idea who I was speaking to asked for nothing more than info about my set up and he spent 45 minutes going all the items that could be a problem, speedo calibration, drive shaft, shifter location, clutch type I would need. On and on REALLY a very nice experiance.
Can't wait to get my new trans installed and see how nice it will be a over drive close ratio shifts. The motor will be dynoed here as I am swapping cams. With up grades to the heads and new cam looking for 400hp ( motor is 350 hp currently)
nice story, keep us up to date!!
Another quality post.
Real Trucks Rattle
Will do , my post was not meant to slam the T-5 set up but in the long run that trans will not hold so it would only be wasted money on my end. Those with very mild engines will do fine the gear ratio thing is here and there. As I have 3.73 and this over drive and first gear ratio are perfect so it really should run great.
I am planning on selling the stock one not sure if there is a market for it but I would let it go CHEAP. It works fine does not leak.
Well the trans showed up today WOW what a great looking piece. Seems a shame to hide it. But really glad i went with the TKo 600 over the 500. The motor got dynoed today. Made 527 hp at the crank. So I am a happy camper. I hope to have the new engine in the truck in a few weeks. Too busy with our shop to get to it now. It is killling me but all in good time.
Why not build a plexiglass tranny cover so you can show it off? A friend of mine did that with the bed on his '37 GMC pick up so he could show off his chromed rear axle,springs and driveline,and "baby's butt-smooth" gloss black frame. Looked great-he even wired it with lights so it sparkled at night. Made the truck sorta-uh-useless,though.
Speed
1954 GMC 350
1957 GMC 1/2 ton
1962 Chevy C-30
'98 Harley FLSTC
'66 Pontiac Catalina
'76 Chevy 1 ton Duallie
'84 Bronco II
'78 Dodge W-200
'81 Toyota 4X4 truck
