7 members (crenwelge, JW51, Lostbuthaulinass, Hugh63c10, Gray_Ghost, 1955 1 Series, greenie-reddy),
161
Mod | | | Forums66 Topics128,108 Posts1,056,237 Members48,437 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Sep 2011 Posts: 814 'Bolter | | 'Bolter Joined: Sep 2011 Posts: 814 | I have a 1956 Chevy half-ton, 235 engine. It has an occasional cough through the carburetor. It doesn't do it every day and when it does cough, it will do it only once and then not again for the rest of the day. Sometimes it's enough to stall the engine. Always happens on acceleration, either leaving from a stop or accelerating in second gear. Everything was rebuilt or replaced about seven years ago. I adjusted the valves and set the timing a little over a year ago. The truck gets driven every day, though it did sit for all of last summer while I was out of town. The cough started some while after I got back. Anyway, I researched the forum on this topic. I understand that an intake valve must be open at the wrong time in order for this to happen. But I've also read that a lean condition can cause a cough out the carburetor, too. My question is, based on the info I've provided, does anyone have a suggestion on where to look first? Haven't started working on it yet but just wanted some advice on where the most likely culprit might be. Don't know if this is related but the exhaust is loose and rattling somewhere, sounds like it's down by the muffler. This started about the same time as the cough. Based on a quick check, it sounds like something is loose inside the muffler. Just thought I'd mention it. Thanks.
1956 Chevy 3200
| | | | | Joined: Jun 2011 Posts: 5,096 Crusing in the Passing Lane | | Crusing in the Passing Lane Joined: Jun 2011 Posts: 5,096 | Look at your accelerator pump circuit.
Ed
| | | | | Joined: Feb 2004 Posts: 29,803 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,803 | Start by doing an "upper cylinder lube" procedure. Get a can of Marvel Mystery Oil or some other lightweight tuneup oil, run the engine at a fast idle, and slowly dribble the oil down the carburetor throat until you get a heavy cloud of smoke from the tailpipe. Then dump enough oil in quickly to stall the engine, or shut the ignition off after giving it the heavy dose of oil. Let the engine soak overnight, then crank it with the throttle wide open until it starts. Goose the gas pedal several times and run the engine at fast idle until the smoke clears. If there are carbon deposits on the intake valves that cause them to stick intermittently, this procedure usually cleans them up. Warn your neighbors what's going on in advance, or you just might get a visit from the local fire department- - - - -the smoke screen will be epic!
If that doesn't help, then dig into the carburetor and inspect the accelerator pump circuit. Jerry
| | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | | | | | | Joined: Nov 2002 Posts: 2,766 Carburetion specialist | | Carburetion specialist Joined: Nov 2002 Posts: 2,766 | Easier than Jerry's suggestion: first check the dwell. A burned projection on one of the points will change the dwell, which will in turn change the timing.
If nothing here, then try Jerry's suggestion.
Jon. Good carburetion is fuelish hot airThe most expensive carburetor is the wrong one you attempt to modify. If you truly believe "one size fits all," try walking a mile in your spouse's shoes!The Carburetor Shop | | | | | Joined: Apr 2005 Posts: 1,971 'Bolter | | 'Bolter Joined: Apr 2005 Posts: 1,971 | cough out of carb is generally a lean condition on the low end.
| | | | | Joined: Sep 2011 Posts: 814 'Bolter | | 'Bolter Joined: Sep 2011 Posts: 814 | Thank you for the replies. I will be following these suggestions and will report back.
1956 Chevy 3200
| | | | | Joined: Oct 2019 Posts: 449 'Bolter | | 'Bolter Joined: Oct 2019 Posts: 449 | Hotrod,
Would the "upper cylinder lube" procedure be a good thing to do anyways for periodic maintenance?
Kevin 1965 Chevy C10 Longbed Fleetside
| | | | | Joined: Feb 2004 Posts: 29,803 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,803 | If a vehicle is run regularly, at least a few times a month, there's really no need to do that. I give my vehicles a good dose of Sea Foam fuel additive on occasion. It can't hurt anything, and it will probably keep deposits from forming on valve stems, etc. Since the OP's truck started giving problems after a fairly long sleep, it's probably got some gum, or maybe a little rust on a valve stem or two. The heavy dose of oil will free that kind of problem up, at least pretty often, without having to do a valve job. Jerry
| | | | | Joined: Feb 2011 Posts: 583 'Bolter | | 'Bolter Joined: Feb 2011 Posts: 583 | I had a 1967 327 V8 that would cough up the carburetor. It was caused by a bad exhaust lobe on the camshaft. The exhaust valve did not open. When the intake valve opened the compressed air would enter the intake manifold and out the carburetor.
Rick
1939 Chevrolet Stake Truck
| | | | | Joined: Jan 2013 Posts: 1,518 'Bolter | | 'Bolter Joined: Jan 2013 Posts: 1,518 | If it were mine, I would pull the valve cover and make a visual on every valve opening and closing, a sticky or tight valve can give you this symptom. 1953 Chevrolet 3100261 cu inch, sm420, 3.55 rear, torque tube still,omaha orange, still 6 volt, RPO green glass, side carrier spare, all done In the DITY GalleryVideo of the 261 running1964 GMC 1000305 Big Block V6, sm420, the next cab off restoration
| | | | | Joined: Sep 2011 Posts: 814 'Bolter | | 'Bolter Joined: Sep 2011 Posts: 814 | If I do this, will I have oil running everywhere? I've never run it with the valve cover off before. Going to do the Marvel Mystery Oil thing tonight. Under cover of darkness.
1956 Chevy 3200
| | | | | Joined: Jan 2010 Posts: 4,263 Shop Shark | | Shop Shark Joined: Jan 2010 Posts: 4,263 | Ive run mine with cover off in the garage, no problems. Thats how some old-timers would adjust the valves. (Not me!)
Good time to check for a bent push rod. | | | | | Joined: Jan 2013 Posts: 1,518 'Bolter | | 'Bolter Joined: Jan 2013 Posts: 1,518 | If I do this, will I have oil running everywhere? I've never run it with the valve cover off before. Going to do the Marvel Mystery Oil thing tonight. Under cover of darkness. No it is not like a small or big block chev, no squirts, nothing will escape the head 1953 Chevrolet 3100261 cu inch, sm420, 3.55 rear, torque tube still,omaha orange, still 6 volt, RPO green glass, side carrier spare, all done In the DITY GalleryVideo of the 261 running1964 GMC 1000305 Big Block V6, sm420, the next cab off restoration
| | | | | Joined: Mar 2010 Posts: 10,280 Renaissance Man | | Renaissance Man Joined: Mar 2010 Posts: 10,280 | The top end of these engines are dribblers, not sprayers. There is no way for oil to escape with the valve cover off.
| | | | | Joined: Sep 2011 Posts: 814 'Bolter | | 'Bolter Joined: Sep 2011 Posts: 814 | I did the upper end lube with Marvel Mystery Oil as suggested. The cough is still there. I notice it's very responsive to the accelerator, like the second you step on the gas, you get the little cough. As I said, it's pretty rare, but it does happen. Days will go by and there's no sign of it and then out of the blue it will happen and then disappear for the next few days. Anyhow, I'm going to take a look at the points and then turn to the carburetor. The points are about a year old, but I suppose they could be messed up somehow. Or maybe the gap isn't right anymore due to wear on the plastic lobe. Anyway, a quick look at that and then on to the carburetor.
1956 Chevy 3200
| | | | | Joined: Sep 2010 Posts: 2,313 'Bolter | | 'Bolter Joined: Sep 2010 Posts: 2,313 | Just throwing it out there maybe the accelerated pump has a defect or dirt , or maybe the little ball bearing that is down there and can’t remember what it does. | | | | | Joined: Sep 2011 Posts: 814 'Bolter | | 'Bolter Joined: Sep 2011 Posts: 814 | I'll be checking the carburetor here pretty soon. I understand that I should look down the throat of the carburetor and operate the throttle and look for a good squirt of gasoline. If that is present, I assume I will need to disassemble the thing and look further, is that correct? Since it's suggested that the accelerator pump could be the problem, I imagine I will have to have a good look at the piston, cup, spring, etc. Any suggestions on what I should be watching out for aside from the obvious broken or worn parts?
1956 Chevy 3200
| | | | | Joined: Jan 2020 Posts: 620 'Bolter | | 'Bolter Joined: Jan 2020 Posts: 620 | Hello, still waiting to hear what you found in the carburetor. If that solved the problem please let me know. Ed
| | | | | Joined: Sep 2011 Posts: 814 'Bolter | | 'Bolter Joined: Sep 2011 Posts: 814 | Getting back to this a year later (or so). I checked the points and found them slightly off. I cleaned them with a points file, reset them, and adjusted the timing. That took care of the problem. For a while. It's been about a year and the cough is back. It did sit all summer again (second summer in a row) without being run. I would say i got a few months' worth of trouble free driving before the problem returned. Too busy to deal with it now but I will be getting to it soon.
1956 Chevy 3200
| | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | Did you "treat" the gasoline in the fuel tank over that one-year period of "rest"?
What kind of gasoline was in the fuel tank (what % Ethanol)? | | | | | Joined: Feb 2004 Posts: 29,803 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,803 | I've never seen an "intermittent" flat cam lobe. Jerry
| | | | | Joined: May 2015 Posts: 11,067 Housekeeping (Moderator) Making a Stovebolt Bed & Paint and Body Shop Forums | | Housekeeping (Moderator) Making a Stovebolt Bed & Paint and Body Shop Forums Joined: May 2015 Posts: 11,067 | I've never seen an "intermittent" flat cam lobe. Jerry Yep, no one has come up with self-healing steel yet.
Kevin 1951 Chevy 3100 work truckFollow this saga in Project JournalPhotos 1929 Ford pickup restored from the ground up. | 1929 Ford Special Coupe (First car) Busting rust since the mid-60's If you're smart enough to take it apart, you darn well better be smart enough to put it back together. | | | | | Joined: Sep 2011 Posts: 814 'Bolter | | 'Bolter Joined: Sep 2011 Posts: 814 | I didn't do anything to the gasoline that was in the tank. No idea what percent ethanol it was, either, though I've cycled through a few tanks of gas since. Back when all this was happening I adjusted the valves. They were all almost perfect and very few needed any adjustment. I'm wondering if the leather piston in the carburetor might have dried up while the car was sitting and maybe now has some kind of problem where it doesn't always function correctly. The problem is really intermittent. It will do it about once every day and that's it. Temperature doesn't make a difference. It does it hot and cold. It does it in all gears. And it happens only when I step on the gas. Just a short cough out the carb. The carb is a Rochester model B that I rebuilt about ten years ago and have never had any trouble with. But I do recall that the throttle shaft seemed a little loose in the body of the carb and I've read that this can cause the problem I'm having. I stated in an earlier post that I did the Marvel Mystery Oil upper end cleaning last year.
1956 Chevy 3200
| | | | | Joined: Feb 2019 Posts: 4,480 AD Addict & Tinkerer | | AD Addict & Tinkerer Joined: Feb 2019 Posts: 4,480 | If you can buy non-ethanol gas in your area it will definitely help with your carb not gumming up during the periods that your truck just sits. Ethanol will start to coagulate in six weeks. I don’t know it that is your problem but it will be if you use gas with ethanol in it. I use non-ethanol gas and I also treat it with Stabil gas treatment. My truck sits thru the winter here in NY and I haven’t (knock on wood) has issues with the carb yet.
Phil Moderator, The Engine Shop, Interiors and Project Journals1952 Chevrolet 3100, Three on the Tree, 4:11 torque tube Updated to: ‘59 235 w/hydraulic lifters, 12v w/alternator, HEI, PCV and Power front Disc BrakesProject JournalsStovebolt Gallery Forum | | | | | Joined: Sep 2011 Posts: 814 'Bolter | | 'Bolter Joined: Sep 2011 Posts: 814 |
1956 Chevy 3200
| | | | | Joined: Mar 2010 Posts: 10,280 Renaissance Man | | Renaissance Man Joined: Mar 2010 Posts: 10,280 | A sticky valve with cause a backfire through the carburetor. A valve can stick from varnish coming from an old gas tank. Ethanol fuel seems to be a wonderful solvent for 70 year old varnish on the sides of the tank. This dissolved varnish makes its way to the valve stem and gums up the guide, causing a miss. It can be intermittent, such as when the engine hasn't warmed up yet.
| | | | | Joined: Sep 2011 Posts: 814 'Bolter | | 'Bolter Joined: Sep 2011 Posts: 814 | I had the gas tank chemical dipped when I rebuilt the truck, so I don't think varnish is an issue.
1956 Chevy 3200
| | | | | Joined: Dec 2018 Posts: 2,450 'Bolter | | 'Bolter Joined: Dec 2018 Posts: 2,450 | joeflanagen You might look for resricted exhaust system by taking your air cleaner off ,then speed it up and watch for gasoline to fly-up out of the carburetor when it comes down. Also will be doggy. | | | | | Joined: Sep 2011 Posts: 814 'Bolter | | 'Bolter Joined: Sep 2011 Posts: 814 | Could a problem in the muffler have any bearing on this? Because it sounds to me like something has come apart inside the muffler. An exhaust restriction maybe?
1956 Chevy 3200
| | | | | Joined: Dec 2018 Posts: 2,450 'Bolter | | 'Bolter Joined: Dec 2018 Posts: 2,450 | War Eagle1 A 3.88$ quart of marvel mystery oil would be a cheap test to answer a question. In the old days they would grind the valve seats with just a 45 degree stone and leave them wide. Didn't know any better,that will contribute to a cough. When they lapped em they had no way to narrow the seat either.Would give it a pint to a tankful and see,also check other stuff mentioned. | | | | | Joined: Sep 2011 Posts: 814 'Bolter | | 'Bolter Joined: Sep 2011 Posts: 814 | I just discovered a pretty good sized crack in my exhaust manifold. Could this have anything to do with the problem?
1956 Chevy 3200
| | | | | Joined: Jun 2011 Posts: 5,096 Crusing in the Passing Lane | | Crusing in the Passing Lane Joined: Jun 2011 Posts: 5,096 | Usually a cracked or loose exhaust manifold will produce a backfire upon letting off on the foot feed, especially when going downhill.
Ed
