Labor Day
Labor Day
MORE wrenching?
Wrenching this Labor Day
Plenty of places to share.
1 members (NJC), 47 guests, and 3 robots.
Topics128,009
Posts1,055,293
Members48,419
#13479 01/12/2005 9:09 PM
I just changed the intake manifold on a 64 283 SB Chev from the stock 4bbl to a weiand 8004. Everything went well until I attempted to put in the distributor.
Everything seemed to go OK & it engaged with no problem but there's about 1/2" gap between the distributor seal ring & the top of the manifold where it should rest. I've tried everything to get it to drop that extra 1/2" but no joy.
Do I not have it in all the way? Or is there a difference in the height of the manifold at this seal point? The new intake is already bolted in (of course) & I can't really tell if there's a height difference. If there is, can it be shimmed?
I've never bumped into this situation before so any "adult supervision" is welcome!
THX,
Bodega
Bodega Bob
http://www.submarinestore.com
Where's my tin foil hat?!?
Disregard! I finally figured out the problem. It wasn't anything to do with the distributor or the manifold. The mechanic (that'd be me) had his head inserted in an incorrect orfice!
Dang, I hate being stupid! It slows down the whole dang process!
Bodega
Bodega Bob
stuff happens, I once ruined a good engine because I did not get the drain cock tight enough after putting antifreeze in it,,, got hot on the way home at 4:oo am , as it was dark and my gauges were not real bright I did not notice till to late, smoke and just stop running, this was in my 70 international half-ton,,,you caught yours before any harm so I would not say you are stupid,,,just an over-site,,regards,,see ya down the road,,,Fred
Redryder pix
My Hotrod
