| | | Forums66 Topics128,049 Posts1,055,678 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Sep 2018 Posts: 42 'Bolter | | 'Bolter Joined: Sep 2018 Posts: 42 | I need to replace the rear spring shackles on my 1940 1/2 ton truck. The bushes are 1.74" long.; the pins are 3.07' long. I have looked on a couple of sites where the parts are listed, but none seem to give dimensions. I am in Australia, so I need a supplier that post to here. Can someone point me in the right direction please? Thanks, Bob | | | | | Joined: May 2015 Posts: 11,031 Housekeeping (Moderator) Making a Stovebolt Bed & Paint and Body Shop Forums | | Housekeeping (Moderator) Making a Stovebolt Bed & Paint and Body Shop Forums Joined: May 2015 Posts: 11,031 | Jim Carter lists them as the same from 1934-1955. Here's a link to their item. 34-55 1/2 ton rear sping shacklesThey may ship to you. It's worth a call to them.
Kevin 1951 Chevy 3100 work truckFollow this saga in Project JournalPhotos 1929 Ford pickup restored from the ground up. | 1929 Ford Special Coupe (First car) Busting rust since the mid-60's If you're smart enough to take it apart, you darn well better be smart enough to put it back together. | | | | | Joined: Feb 2000 Posts: 5,200 'Bolter | | 'Bolter Joined: Feb 2000 Posts: 5,200 | Start here, http://chevy.oldcarmanualproject.com/parts/1929_54/434.htm , page 434 of the 1929 - 1954 parts manual. Locate the parts you are interested in on the drawing, then scroll through the next few pages to fine what all they fit. Looks like 1933 - 1954 1/2 tons all used the same shackles and pins.
| | | | | Joined: Sep 2018 Posts: 42 'Bolter | | 'Bolter Joined: Sep 2018 Posts: 42 | Once again, thanks for the help. Jim Carter has them on back order, but I actually located a set in Australia this morning (at a greater cost though), so I'm set. I will post a picture of my pickup when it's all finished. | | |
