| | | Forums66 Topics128,154 Posts1,056,855 Members48,456 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jun 2005 Posts: 128 Wrench Fetcher | | Wrench Fetcher Joined: Jun 2005 Posts: 128 | Hello fellas this is my first time in the hipo shop Iam usually in the paint and body .My problem is not on a truck but a boat with a GM engine.It all started with the old quadra jet flooding,fuel pouring all over,so I get a kit have a good mechanic install it,works fine for one tank of fuel about fourty gallons.Then it does it again,same thing,throw the quad away and buy a brand new edelbrock marine carb which worked great at cruise but when I come of step and try to cruise under 1200 rpm she floods ,not to the point of boiling over but the engine just loads up with fuel.I have a brand new raycor fuel filter and a manual pump which I tested,it had 4.5 on the gauge.I tryed a new pump but it was no good out of the box,Iam thinking of going with an electric, with a fuel presure regulator,but come on it's just a 305 with a four barrel help!!!!!1 | | | | | Joined: Dec 2003 Posts: 510 Shop Shark | | Shop Shark Joined: Dec 2003 Posts: 510 | I had the same problem on a Chevy smallblock with an Edelbrock fuel pump. If flooded and leaked gas (even caught fire once) and all sorts of unpleasant stuff...with several different carbs.
I, too, put a pressure gauge on it and the pressure appeared to be fine. But out of desperation I put a pressure regulator on it, turned it down almost to its mininmum setting and never had another problem with it. Regulators are cheap...I think I paid under $20 for it...and it might be worth a try. | | | | | Joined: Jun 2005 Posts: 128 Wrench Fetcher | | Wrench Fetcher Joined: Jun 2005 Posts: 128 | Thanks for the reply chevy,my nieghbour just said something interesting.He asked where I mounted my raycour fuel filter,before or after the pump,well I mounted it before and it is quite a filter ,he feels my pump may not have enough vacume at low rpm to suck through all that crap and maybe it is starving not flooding mmmmmmmmmmmmm...? | | | | | Joined: Dec 2003 Posts: 510 Shop Shark | | Shop Shark Joined: Dec 2003 Posts: 510 | Well, that fuel filter thing otta be easy enough to diagnose. Just bypass it with a length of hose. | | | | | Joined: Jun 2005 Posts: 128 Wrench Fetcher | | Wrench Fetcher Joined: Jun 2005 Posts: 128 | Just checked the filter,it's got water in it drain the tank oh boy,what a chore in a boat ,good thing I've got a vacume recovery unit oh ya the filter is in the right place should have checked this first!!!!!! | | |
