7 members (Donf, 46 Texaco, Southerntruck, Nick in Manitou, Hotrod Lincoln, 2 invisible), 88 guests, and 2 robots.
Topics128,115
Posts1,056,633
Members48,450
#134706 07/10/2006 3:31 PM
Hello fellas this is my first time in the hipo shop Iam usually in the paint and body .My problem is not on a truck but a boat with a GM engine.It all started with the old quadra jet flooding,fuel pouring all over,so I get a kit have a good mechanic install it,works fine for one tank of fuel about fourty gallons.Then it does it again,same thing,throw the quad away and buy a brand new edelbrock marine carb which worked great at cruise but when I come of step and try to cruise under 1200 rpm she floods ,not to the point of boiling over but the engine just loads up with fuel.I have a brand new raycor fuel filter and a manual pump which I tested,it had 4.5 on the gauge.I tryed a new pump but it was no good out of the box,Iam thinking of going with an electric, with a fuel presure regulator,but come on it's just a 305 with a four barrel help!!!!!1
Bent Happy Haulin!
TWO 1963 GMC\'s -- A shortbox and a NAPCO!
#134707 07/10/2006 5:11 PM
I had the same problem on a Chevy smallblock with an Edelbrock fuel pump. If flooded and leaked gas (even caught fire once) and all sorts of unpleasant stuff...with several different carbs.
I, too, put a pressure gauge on it and the pressure appeared to be fine. But out of desperation I put a pressure regulator on it, turned it down almost to its mininmum setting and never had another problem with it. Regulators are cheap...I think I paid under $20 for it...and it might be worth a try.
#134708 07/10/2006 6:18 PM
Thanks for the reply chevy,my nieghbour just said something interesting.He asked where I mounted my raycour fuel filter,before or after the pump,well I mounted it before and it is quite a filter ,he feels my pump may not have enough vacume at low rpm to suck through all that crap and maybe it is starving not flooding mmmmmmmmmmmmm...?
Bent Happy Haulin!
#134709 07/11/2006 4:04 PM
Well, that fuel filter thing otta be easy enough to diagnose. Just bypass it with a length of hose.
#134710 07/11/2006 4:21 PM
Just checked the filter,it's got water in it drain the tank oh boy,what a chore in a boat ,good thing I've got a vacume recovery unit oh ya the filter is in the right place should have checked this first!!!!!!
Bent Happy Haulin!
