3 members (Hotrod Lincoln, BC59, 1 invisible),
134
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,047 Posts1,055,538 Members48,424 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Apr 2006 Posts: 51 Member | | Member Joined: Apr 2006 Posts: 51 | Hi their, so i am leaning towards going with a big block in my 54, i cant recall seeing one before and im not 100% sure what will work. First of all i want to make sure it can be done. I am going to use a 77 firebird frame clip and have access to a 400bb pontiac. Is there going to be any other major work need to be done to the firewall or floor to house this thing?
thanks, Tony
old iron vs. new plastic....no brainer! TECH WANTED: on S-10 frame swap PARTS WANTED: 54 Visor, weather strips.. PARTS FOR SALE: I have complete frame / complete driveline from 54 1/2ton. very solid, will seperate 1954 GMC 3100 | | | | | Joined: May 2005 Posts: 8,878 . | | . Joined: May 2005 Posts: 8,878 | I have a feeling that with a front frame swap the engine and trans will be low enough that floor clearence won't be a problem. As for firewall you will have to measure center of front wheel to firewall on both vehicles and see for your self. | | | | | Joined: Oct 2003 Posts: 5,152 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Oct 2003 Posts: 5,152 | I've seen big block Chevys in these trucks, but don't know that I've ever seen a big Pontiac in one. I'm sure it can be done, and if you are using the Firebird clip some of the problems (like steering interference) will be taken care of as part of the clip project.
Firewall and floor really depend on where you mount the motor. As you clip the truck you'll be deciding how much to lower the truck, and that will affect your options for mounting the motor.
I've always thought it would be fun to get some of the GMC valve covers used on '55 to '59 GMC V-8 powered trucks because many of those motors were Pontiacs. I believe the GMC logo is actually a decal, not embossed, but I understand that though it may take two gaskets to ensure enough room rockers to move, it seems like a fun way to make that big Pontiac look like it grew there under that GMC hood.
Good Guys Puyallip in next weekend. There is a guy who usually shows his '54 (actually its a '55 1st, but he calls it a '54) GMC with an Olds clip and a 454 Chevy under the hood. If you make the trip you might want to look for it.
1955 1st GMC Suburban | 1954 GMC 250 trailer puller project | 1954 GMC 250 Hydra-Matic | 1954 Chevy 3100 . 1947 Chevy COE | and more... It's true. I really don't do anything but browse the Internet looking for trouble... | | | | | Joined: May 2006 Posts: 8,351 'Bolter | | 'Bolter Joined: May 2006 Posts: 8,351 | Just a comment on Pontiac engines; there is no such thing as a "big block" Pontiac. The block is the same dimensions for all displacements, Oldsmobiles are the same way. How 'bout a sleeper, you know, 287 badging on a 428 Suoer Duty or 455 HO?
Bill Burmeister | | | | | Joined: Jul 2006 Posts: 53 Wrench Fetcher | | Wrench Fetcher Joined: Jul 2006 Posts: 53 | With the 396 in my half ton the frame had to be notched and the steering box moved. The firewall had to be banged in about an inch in the middle to make way for the distributor.
I think the Pontiac sounds like a very cool idea. I've seen bolts with bigger chevy's, but no Pontiacs. | | | | | Joined: Mar 2004 Posts: 154 Member | | Member Joined: Mar 2004 Posts: 154 | i totally support the idea of using a big ol' BOP. theres a 455 Olds sitting in a '72 Delta 88 out back that just screams "rebuild me and make me fast!"
yeah. it's very tempting.
tho they may only put out about 300 horse in some instances...with 500+ ft/lbs torque naturally aspirated and fairly stock..how can you NOT dig these old 400+ BOPs??
i say, do it.
.later days. .sam. 1969 K20 , with a '67 front clip. fleetside. 292, 3x1 offy, headers. sm465 4spd. getting put back together, almost ready for paint. doing it all myself. 19 and lovin' it. "proper" is so over-rated. .later days. .sam.
| | | | | Joined: Dec 2002 Posts: 3,439 Moderator - The Electrical Bay | | Moderator - The Electrical Bay Joined: Dec 2002 Posts: 3,439 | The Olds 425-455 is about an inch taller, and an inch wider than the 350 block.
One thing about BB Olds, is they dont like high RPM's unless they are put together with matched parts.
