5 members (Mike B, Otto Skorzeny, Ponchogl, moparguy, 1 invisible), 86 guests, and 4 robots.
Topics128,180
Posts1,057,154
Members48,464
I
I Offline
I have a 1953 3600 but seems to have a 1958-62 235 from a car. but in any case I am replacing the exhaust and intake manifold gaskets. Should I separate the intake and exhaust? Or can I just leave them together and take it down and get the surface milled? The heat flapper does seem to move freely.
1953 3600
If you don't have a problem with the manifolds just leave them as they are. Consider using a Remflex manifold gasket, which is a thick compressable single gasket that can take up to 1/8 inch gap. They are somewhat pricey at around $40 but that is a lot less expensive than having a machine shop mill that long manifold.
Kent
1937 Chevy 1/2 ton
1942 Chevy 1/2 ton
1947 Diamond T Model 509
1951 Chevy 1/2 ton
Use a straight edge such as a long carpenter's level to check for misalignment between the two manifolds. Once you separate the two, it can be hard to get them back into proper alignment on re-installation. Leaving the four intake/exhaust bolts slightly loose while getting the manifolds snugged up to the head helps, then tighten them last.
1 Offline
Separating them you risk breaking off one or more studs with all the hassle that entails. If you don't have to, don't.
1951 3800 1-ton
In the DITY Gallery
I
I Offline
I will order a Remflex right now. I used them before, excellent gaskets.
1953 3600
