| | | Forums66 Topics128,166 Posts1,057,092 Members48,463 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Sep 2019 Posts: 12 New Guy | | New Guy Joined: Sep 2019 Posts: 12 | I have a 1953 3600 but seems to have a 1958-62 235 from a car. but in any case I am replacing the exhaust and intake manifold gaskets. Should I separate the intake and exhaust? Or can I just leave them together and take it down and get the surface milled? The heat flapper does seem to move freely.
1953 3600
| | | | | Joined: Apr 2007 Posts: 1,038 'Bolter | | 'Bolter Joined: Apr 2007 Posts: 1,038 | If you don't have a problem with the manifolds just leave them as they are. Consider using a Remflex manifold gasket, which is a thick compressable single gasket that can take up to 1/8 inch gap. They are somewhat pricey at around $40 but that is a lot less expensive than having a machine shop mill that long manifold. Kent | | | | | Joined: Feb 2004 Posts: 29,872 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,872 | Use a straight edge such as a long carpenter's level to check for misalignment between the two manifolds. Once you separate the two, it can be hard to get them back into proper alignment on re-installation. Leaving the four intake/exhaust bolts slightly loose while getting the manifolds snugged up to the head helps, then tighten them last. Jerry
| | | | | Joined: Jul 2014 Posts: 892 'Bolter | | 'Bolter Joined: Jul 2014 Posts: 892 | Separating them you risk breaking off one or more studs with all the hassle that entails. If you don't have to, don't. 1951 3800 1-ton"Earning its keep from the get-go"In the DITY Gallery1962 261 (w/cam, Fenton headers, 2 carbs, MSD ign.), SM420 & Brown-Lipe 6231A 3spd aux. trans, stock axles & brakes. Owned since 1971. | | | | | Joined: Sep 2019 Posts: 12 New Guy | | New Guy Joined: Sep 2019 Posts: 12 | I will order a Remflex right now. I used them before, excellent gaskets.
1953 3600
