2 members (Gdads51, WICruiser),
84
Mod | | | Forums66 Topics128,268 Posts1,058,319 Members48,485 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Dec 2019 Posts: 33 'Bolter | | 'Bolter Joined: Dec 2019 Posts: 33 | considering front disk. what's the best way to go for cost and quality? also can I keep the master cylinder location under the floor wit a duel m/c? what do you recommend for a M/C and conversion?? 49 3100
| | | | | Joined: Jan 2013 Posts: 2,238 Moderator: Interiors, Texas Bolters, Name that Part | | Moderator: Interiors, Texas Bolters, Name that Part Joined: Jan 2013 Posts: 2,238 | I think I did mine through CPP. I have disc up front with dual cylinder under cab. Just a note, due to the width it doesn’t line up perfectly. Mine was 1/2 off.
Almost forgot, you will need to adjust brake lines due to requiring a portioning valve in line. Chris
| | | | | Joined: Nov 2006 Posts: 8 'Bolter | | 'Bolter Joined: Nov 2006 Posts: 8 | I got my kit thru speedway it was the cheapest. Maybe $225-250 They (Vendors) sell m/c for under floorboard mounting. And yes a proportioning valve is necessary. I believe you can also still get a six lug brake kit. Mine is the Chevy 5 lug on 4.75 bolt pattern. So your wheel setup might be an issue. But stopping is the most important part......upgrade! But some of it depends if you’re going to update the wheels. | | | | | Joined: Jan 2016 Posts: 631 'Bolter | | 'Bolter Joined: Jan 2016 Posts: 631 | Many of the kits are “made” or compiled by just few suppliers. So they are built or made to a price point........sold to many different venders.
Some are complete are actually designed to work together...........like master cylinder and portioning valve.
Many kits recommended replacing the ball bearings with tapered roller bearings. Replacing the hubs is great option and often cheaper than just the bearing when purchased in a complete kit.
I would replace all the brake lines during the install.
