5 members (Otto Skorzeny, Jay R, carbking, Gdads51, mick53), 96 guests, and 2 robots.
Topics128,259
Posts1,058,298
Members48,485
rad
Offline
considering front disk. what's the best way to go for cost and quality? also can I keep the master cylinder location under the floor wit a duel m/c? what do you recommend for a M/C and conversion?? 49 3100
I think I did mine through CPP. I have disc up front with dual cylinder under cab. Just a note, due to the width it doesn’t line up perfectly. Mine was 1/2 off.
Almost forgot, you will need to adjust brake lines due to requiring a portioning valve in line.
Chris
I got my kit thru speedway it was the cheapest. Maybe $225-250
They (Vendors) sell m/c for under floorboard mounting. And yes a proportioning valve is necessary. I believe you can also still get a six lug brake kit. Mine is the Chevy 5 lug on 4.75 bolt pattern. So your wheel setup might be an issue. But stopping is the most important part......upgrade! But some of it depends if you’re going to update the wheels.
Many of the kits are “made” or compiled by just few suppliers. So they are built or made to a price point........sold to many different venders.
Some are complete are actually designed to work together...........like master cylinder and portioning valve.
Many kits recommended replacing the ball bearings with tapered roller bearings. Replacing the hubs is great option and often cheaper than just the bearing when purchased in a complete kit.
I would replace all the brake lines during the install.
