5 members (Guitplayer, tclederman, Leo, stlcardinalsguy, FAST55), 65 guests, and 2 robots.
Topics128,050
Posts1,055,673
#134565 06/27/2006 12:37 AM
Can you use a torque converter from a 350 turbo in a 400 turbo?
#134566 06/27/2006 3:11 AM
Yep, no problem. Now, what-cha up to?
mv
46 Chev One Ton Panel - S10 Frame Project
"What if the Hokey-Pokey is REALLY what it's all about?" - J. Buffet
#134567 06/28/2006 5:20 AM
I disagree with mike. t400 torque converter is different than a t350. There is a 1/2 inch difference between the two input shafts.
#134568 06/28/2006 10:19 PM
I just double checked some part numbers on the B&M site. If you check part #20480, it fits TH350, TH375, TH400 & TH425. I think there *were* infact, TH400 with a different input shaft (as mentioned) in the early 60's. Don't hold me to this, but I believe they were compatible with the early *switch-pitch* converters.
As a related sidebar, in the 80's I had a friend with a budget 427 Chevelle drag car who ran a 10-inch junkyard Vega TH350 convertor in a TH400. I don't condone using stock Vega converters behind BBCs but it works! er, for a while anyway <grin>. It stalled around 3500 RPM for 2 seasons, then started getting looser in the middle of the third summer of racing. The cars slowed at that point too.
MV
#134569 06/29/2006 3:42 AM
A buddy of mine ran the Vega converter in a mud runner for several seasons. As long as the tires were spinning, he had no problems. The truck was not street legal so it held up well.
Scott
Scott Ward
2 1948 1.5-ton Loadmasters
1 1950 3100
1 1955.1 Chevy 6500
1 1954 Chevy 6500 2-Ton
1 1955 1st Series COE 5700
1 1963 K20 (454)
1 1964 C10 (350)
1 1951 1.5-ton Dump Truck
1953 and a 1956 Ford F800
#134570 06/29/2006 3:53 AM
Sorry, thought you were talking about stock converters. I put a t400 into my 84 chev and it didnt work, but like you said it was an old t400 that i was using.
#134571 06/29/2006 4:51 PM
thanx guys,any other input is welcome.
Lothar
PS, the weather is great here in the lower mainland right now ,eh Motorhead?Are you going to the Langley cruise in in Sept?
#134572 06/30/2006 12:55 AM
Junior Member
Junior Member
In 1984 the trans would have been a 350C which
is a 350 trans with a lockup converter. The input
shaft on the 350C is longer to supply oil to the
lockup clutch. The 350C converter will not work
with a 400 trans. From the info I've seen the switch pitch converters were not an option in Chevy models. The converters from a 350 or 400
are interchangeable.
Arnie
#134573 06/30/2006 6:03 AM
Quote
Are you going to the Langley cruise in in Sept? [/QB]
id like to but truck wont be ready till next summer.
#134574 07/01/2006 10:25 PM
I've gone 3 out of the 9 times ,just because I look to see how other AD owners have built their trucks.It's the only run I ever go to,because they usually have about 1500 vehicles and it's free(the best part)I never go to any other shows because they rarely have any AD trucks and they charge too much.I have some spare parts,if you do too ,we could trade off some of our uneeded parts,seeing as you only live about 1/2 hour from me.
Lothar
#134575 07/02/2006 4:20 AM
Thanks arnie, that makes sense re: the TH350c.
mv
