11 members (Hotrod Lincoln, J Lucas, Youngin' Tut 59, 5 Window 9434, lumbersawyer, klhansen, DougH6100, MNSmith, Pete1946, Shade Baby, 1 invisible),
88
Mod | | | Forums66 Topics128,139 Posts1,056,762 Members48,454 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Feb 2001 Posts: 95 'Bolter | | 'Bolter Joined: Feb 2001 Posts: 95 | Would the under bellhousing crossmember from a 67-72 C60 or a 73 and newer C60 interchange with a 64 C60? For reference my 64 bellhousing casting number is 3779388 and has the large 197 tooth flywheel with 13 inch clutch. I note this as I have seen other 60-66 C60 trucks with a smaller bellhousing, flywheel and clutch incase this makes a difference in the crossmember.
I will need a replacement crossmember for a 64 C60 but the yards I know of only have the 67 and newer C60’s
I appreciate any help on this. | | | | | Joined: Nov 2005 Posts: 6,100 'Bolter | | 'Bolter Joined: Nov 2005 Posts: 6,100 | Hy red450IH, according to my parts book, support, engine rear, group 7.011 is the same for gas six cylinder engines between 1963-66, a different part number for V8 gas engines exc.409 between 1963-66, these are specifications for the 60 series. The 1967 and newer trucks all have different part numbers for that part. Hope that informs. | | | | | Joined: Feb 2001 Posts: 95 'Bolter | | 'Bolter Joined: Feb 2001 Posts: 95 | 3B, thank you for the information - much appreciated. Would this also mean there is specific bellhousing for a six cylinder and a V8 in 63-66? Also would 67-72 have a different crossmember and bellhousing for each, a six cylinder and a V8?
This should help me narrow down the crossmembers to consider looking for in salvage yards. | | | | | Joined: Aug 2016 Posts: 14 Wrench Fetcher | | Wrench Fetcher Joined: Aug 2016 Posts: 14 | I think since u are using the adapter for large clutch I would think that a later cross member should work, note the later frame is wider I believe get out your tape measure! | | |
