1 members (5 Window 9434),
68
Mod | | | Forums66 Topics128,030 Posts1,055,428 Members48,422 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jan 2020 Posts: 96 'Bolter | | 'Bolter Joined: Jan 2020 Posts: 96 | Just wondering everyones opinion, Do you recommend keeping the original paint color shown on the title or do a custom paint job. The original pain was black. What paint combinations do you recommend and interior colors?
Colton Kenshol Hermiston, Oregon
1950 Chevy 3100 216 Motor Mostly Original..
| | | | | Joined: May 2015 Posts: 11,004 Housekeeping (Moderator) Making a Stovebolt Bed & Paint and Body Shop Forums | | Housekeeping (Moderator) Making a Stovebolt Bed & Paint and Body Shop Forums Joined: May 2015 Posts: 11,004 | If you're referring to the truck you posted about the door alignment, I kind of like the color it is now. Black is tough to get looking good as it tends to highlight any imperfection in the bodywork. Just wondering why you want to repaint it.
BTW, you should go to your profile and fill out a signature with info about your truck, then everyone won't have to play detective to see what you're working on. I went to your previous posts to discover what truck you were referring to.
Kevin 1951 Chevy 3100 work truckFollow this saga in Project JournalPhotos 1929 Ford pickup restored from the ground up. | 1929 Ford Special Coupe (First car) Busting rust since the mid-60's If you're smart enough to take it apart, you darn well better be smart enough to put it back together. | | | | | Joined: Jan 2020 Posts: 96 'Bolter | | 'Bolter Joined: Jan 2020 Posts: 96 | Thanks Klhansen, I like the color too but I really like that deep maroon with metallic flake. Just want other color options that might make the pick-up really stand out. I didnt think about my profile, have been on here very long.. Im headed there right now to correct it..
| | | | | Joined: Dec 2001 Posts: 14,522 Moderator: Welcome Centre, Southern Bolters, Legion Hall | | Moderator: Welcome Centre, Southern Bolters, Legion Hall Joined: Dec 2001 Posts: 14,522 | Its your truck.......do as you wish. My vote would be to paint it black and put big white walls on it.....that will make it stand out and also allow for a change later on. (why should I talk, I have a coupe that is originally Black but painting it.......yep, Crimson which is more of a maroon than a red)
